주요 콘텐츠로 건너뛰기
HP Officejet J3680 Phone Cord Replacement
필요한 것
  1. HP Officejet J3680 Phone Cord Replacement, Unplug phone cord from handset: 1 단계, 이미지 1/1
    • Unplug one end of the cord by squeezing the plastic piece and pulling it out from the handset as shown on the left.
  2. HP Officejet J3680 Phone Cord Replacement, Unplug phone cord from back of device: 2 단계, 이미지 1/1
    • Turn the device over to see the bottom as shown on the left.
    • First, slide the cord out from under the plastic clip.
    • Then as done in step one, squeeze the plastic piece to remove it from the back of the device.
결론
To reassemble your device, follow these instructions in reverse order. You will know the plastic piece has been inserted correctly if you hear it click into place.
Marisa
회원 가입일: 10/22/14
206 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 1-1, Duarte Fall 2014 UMass Dartmouth, Team 1-1, Duarte Fall 2014 회원
UMASSD-DUARTE-F14S1G1
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 231
