주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
Are the buttons not working on your printer? Consider using this guide to replace the buttons in your device.
부품
지정된 부품이 없습니다.
  1. Insert 2 fingers in the dent on the right side of the printer and pull towards the front of the printer. Using fingers to open the cover of the scanner which located on the top of the printer.
    • Insert 2 fingers in the dent on the right side of the printer and pull towards the front of the printer.
    • Using fingers to open the cover of the scanner which located on the top of the printer.
  2. Remove four 10mm screws on the panel with T8 torx security screwdriver. Remove the cover of the top part. Remove the cover of the top part.
    • Remove four 10mm screws on the panel with T8 torx security screwdriver.
    • Remove the cover of the top part.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Remove eight 10mm screws on the back of the controlling keyboard with T8 torx security screwdriver. Remove the back board of the controlling keyboard. Remove the back board of the controlling keyboard.
    • Remove eight 10mm screws on the back of the controlling keyboard with T8 torx security screwdriver.
    • Remove the back board of the controlling keyboard.
  5. Remove the button that is located at the left of the controlling keyboard. Remove the button that is located at the left of the controlling keyboard. Remove the button that is located at the left of the controlling keyboard.
    • Remove the button that is located at the left of the controlling keyboard.
결론
Jiayin Zhu
회원 가입일: 2018년 10월 21일
349 평판
안내서 3개 작성하였습니다
UC Davis, Team S11-G8, Lore Fall 2018 UC Davis, Team S11-G8, Lore Fall 2018 회원
UCD-LORE-F18S11G8
3 회원들
안내서 4개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 61
