주요 콘텐츠로 건너뛰기
HP Officejet J4550 All-in-one Paper-Feed Roller Replacement
필요한 것
  1. HP Officejet J4550 All-in-one Paper-Feed Roller Replacement, Paper-Feed Roller: 1 단계, 이미지 1/2 HP Officejet J4550 All-in-one Paper-Feed Roller Replacement, Paper-Feed Roller: 1 단계, 이미지 2/2
    • Open the document feeder cover by flipping it to the left with the front panel facing you.
    • Locate the manual paper-feed roller end of the document feeder cover.
  2. HP Officejet J4550 All-in-one Paper-Feed Roller Replacement: 2 단계, 이미지 1/1
    • Remove the 10mm screw on the side of the roller with T8 torx security screwdriver.
  3. HP Officejet J4550 All-in-one Paper-Feed Roller Replacement: 3 단계, 이미지 1/2 HP Officejet J4550 All-in-one Paper-Feed Roller Replacement: 3 단계, 이미지 2/2
    • Pull the side cover of the paper-feed roller to the right and remove the paper roller.
결론
Jiayin Zhu
회원 가입일: 10/21/18
376 평판
안내서 3개 작성하였습니다
UC Davis, Team S11-G8, Lore Fall 2018 UC Davis, Team S11-G8, Lore Fall 2018 회원
UCD-LORE-F18S11G8
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 374
