주요 콘텐츠로 건너뛰기
HP Officejet Pro 6835 AC Power Adapter Replacement
필요한 것
  1. HP Officejet Pro 6835 AC Power Adapter Replacement, AC Power Adapter: 1 단계, 이미지 1/3 HP Officejet Pro 6835 AC Power Adapter Replacement, AC Power Adapter: 1 단계, 이미지 2/3 HP Officejet Pro 6835 AC Power Adapter Replacement, AC Power Adapter: 1 단계, 이미지 3/3
    • Use a T9 torx screwdriver to remove one (1) 10mm screw by turning it counterclockwise.
    • Grab the backplate and pull it towards you to remove it.
  2. HP Officejet Pro 6835 AC Power Adapter Replacement: 2 단계, 이미지 1/1
    • Grab the AC Power Adapter and pull it towards you to slide it out.
  3. HP Officejet Pro 6835 AC Power Adapter Replacement: 3 단계, 이미지 1/1
    • Grab the base of the colored, braided cable and pull it out of the AC Power Adapter.
결론
Jake Park
회원 가입일: 01/24/18
465 평판
안내서 2개 작성하였습니다
Cal Poly, Team S2-G4, Livingston Winter 2018 Cal Poly, Team S2-G4, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S2G4
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 720
