주요 콘텐츠로 건너뛰기
HP Officejet Pro 6835 Encoder Strip Replacement
필요한 것
  1. HP Officejet Pro 6835 Encoder Strip Replacement, HP Officejet Pro 6835 Cover Disassembly: 1 단계, 이미지 1/1
    • Open the main lid as far as it will go.
    • Use a plastic opening tool to gently pry off the hinge on the right side by pushing it to the left and off the hook.
    • Open the lid further.
  2. HP Officejet Pro 6835 Encoder Strip Replacement: 2 단계, 이미지 1/3 HP Officejet Pro 6835 Encoder Strip Replacement: 2 단계, 이미지 2/3 HP Officejet Pro 6835 Encoder Strip Replacement: 2 단계, 이미지 3/3
    • Use a T9 torx screwdriver to remove a total of ten (10) 12mm screws from the main cover by turning the screwdriver counterclockwise.
    • The two screws above the screen assembly are deep so you may need a long screwdriver.
  3. HP Officejet Pro 6835 Encoder Strip Replacement: 3 단계, 이미지 1/1
    • Grab the main cover and lift it up slightly.
    • Do not pull too hard—there is a cable connecting the cover to the printer.
  4. HP Officejet Pro 6835 Encoder Strip Replacement: 4 단계, 이미지 1/2 HP Officejet Pro 6835 Encoder Strip Replacement: 4 단계, 이미지 2/2
    • Grab the base of the white ribbon cable connecting the cover to the base of the printer and pull it out.
  5. HP Officejet Pro 6835 Encoder Strip Replacement, Encoder Strip: 5 단계, 이미지 1/2 HP Officejet Pro 6835 Encoder Strip Replacement, Encoder Strip: 5 단계, 이미지 2/2
    • Push the hook that is attached to the encoder strip towards the center of the printer.
    • Hold the hook pushed in and pull the strip off of the hook.
    • Repeat on the other side of the encoder strip.
    • During reassembly, the black triangle on the encoder strip should be on the right side of the printer.
  6. HP Officejet Pro 6835 Encoder Strip Replacement: 6 단계, 이미지 1/1
    • Carefully slide the encoder strip out from the carriage.
결론
David J
회원 가입일: 01/24/18
169 평판
안내서 2개 작성하였습니다
Cal Poly, Team S2-G4, Livingston Winter 2018 Cal Poly, Team S2-G4, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S2G4
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 27
전체 시간: 1,923
