주요 콘텐츠로 건너뛰기
HP Officejet Pro 6835 Sensor Chip Replacement
필요한 것
  1. HP Officejet Pro 6835 Sensor Chip Replacement, HP Officejet Pro 6835 Cover Disassembly: 1 단계, 이미지 1/1
    • Open the main lid as far as it will go.
    • Use a plastic opening tool to gently pry off the hinge on the right side by pushing it to the left and off the hook.
    • Open the lid further.
  2. HP Officejet Pro 6835 Sensor Chip Replacement: 2 단계, 이미지 1/3 HP Officejet Pro 6835 Sensor Chip Replacement: 2 단계, 이미지 2/3 HP Officejet Pro 6835 Sensor Chip Replacement: 2 단계, 이미지 3/3
    • Use a T9 torx screwdriver to remove a total of ten (10) 12mm screws from the main cover by turning the screwdriver counterclockwise.
    • The two screws above the screen assembly are deep so you may need a long screwdriver.
  3. HP Officejet Pro 6835 Sensor Chip Replacement: 3 단계, 이미지 1/1
    • Grab the main cover and lift it up slightly.
    • Do not pull too hard—there is a cable connecting the cover to the printer.
  4. HP Officejet Pro 6835 Sensor Chip Replacement: 4 단계, 이미지 1/2 HP Officejet Pro 6835 Sensor Chip Replacement: 4 단계, 이미지 2/2
    • Grab the base of the white ribbon cable connecting the cover to the base of the printer and pull it out.
  5. HP Officejet Pro 6835 Sensor Chip Replacement, Sensor Chip: 5 단계, 이미지 1/1
    • Twist the screwdriver counter-clockwise to remove the T9 screw on the sensor chip.
  6. HP Officejet Pro 6835 Sensor Chip Replacement: 6 단계, 이미지 1/1
    • Pick up the sensor chip by the edges.
    • Pull the white cable to disconnect it from the sensor chip.
    • Repeat the process with the cable on the bottom.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Dimitri Charitou
회원 가입일: 01/24/18
489 평판
안내서 2개 작성하였습니다
Cal Poly, Team S2-G4, Livingston Winter 2018 Cal Poly, Team S2-G4, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S2G4
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 12
전체 시간: 1,018
