소개
The sensor chip is a small, green chip located in the top-right corner inside printer. It is held in by a small screw.
필요한 것
Open the main lid as far as it will go.
Use a plastic opening tool to gently pry off the hinge on the right side by pushing it to the left and off the hook.
Open the lid further.
Twist the screwdriver counter-clockwise to remove the T9 screw on the sensor chip.
다른 한 분이 해당 안내서를 완성하였습니다.
