주요 콘텐츠로 건너뛰기
HP Officejet Pro 6835 Speaker Replacement
필요한 것
  1. HP Officejet Pro 6835 Speaker Replacement, HP Officejet Pro 6835 Cover Disassembly: 1 단계, 이미지 1/1
    • Open the main lid as far as it will go.
    • Use a plastic opening tool to gently pry off the hinge on the right side by pushing it to the left and off the hook.
    • Open the lid further.
  2. HP Officejet Pro 6835 Speaker Replacement: 2 단계, 이미지 1/3 HP Officejet Pro 6835 Speaker Replacement: 2 단계, 이미지 2/3 HP Officejet Pro 6835 Speaker Replacement: 2 단계, 이미지 3/3
    • Use a T9 torx screwdriver to remove a total of ten (10) 12mm screws from the main cover by turning the screwdriver counterclockwise.
    • The two screws above the screen assembly are deep so you may need a long screwdriver.
  3. HP Officejet Pro 6835 Speaker Replacement: 3 단계, 이미지 1/1
    • Grab the main cover and lift it up slightly.
    • Do not pull too hard—there is a cable connecting the cover to the printer.
  4. HP Officejet Pro 6835 Speaker Replacement: 4 단계, 이미지 1/2 HP Officejet Pro 6835 Speaker Replacement: 4 단계, 이미지 2/2
    • Grab the base of the white ribbon cable connecting the cover to the base of the printer and pull it out.
  5. HP Officejet Pro 6835 Speaker Replacement, Speaker: 5 단계, 이미지 1/3 HP Officejet Pro 6835 Speaker Replacement, Speaker: 5 단계, 이미지 2/3 HP Officejet Pro 6835 Speaker Replacement, Speaker: 5 단계, 이미지 3/3
    • Grab the intertwined red and black wires. Gently pull up and disconnect the wires from the motherboard.
    • Be careful to remove the wires from the socket, NOT the socket from the board.
  6. HP Officejet Pro 6835 Speaker Replacement: 6 단계, 이미지 1/1
    • Carefully slide the speaker out of the printer.
결론
David J
회원 가입일: 01/24/18
169 평판
안내서 2개 작성하였습니다
Cal Poly, Team S2-G4, Livingston Winter 2018 Cal Poly, Team S2-G4, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S2G4
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 289
