주요 콘텐츠로 건너뛰기
HP Officejet Pro 8600 Plus Front Panel Replacement
필요한 것
  1. HP Officejet Pro 8600 Plus Front Panel Replacement, Front Panel: 1 단계, 이미지 1/2 HP Officejet Pro 8600 Plus Front Panel Replacement, Front Panel: 1 단계, 이미지 2/2
    • Open the front panel door by pulling forward on the slot located on the front-left side of the printer.
  2. HP Officejet Pro 8600 Plus Front Panel Replacement: 2 단계, 이미지 1/2 HP Officejet Pro 8600 Plus Front Panel Replacement: 2 단계, 이미지 2/2
    • Insert the plastic opening tool into the right socket connecting the front panel door to the hinge guide.
    • Pry the socket open, lifting the door hinge guide out of place.
  3. HP Officejet Pro 8600 Plus Front Panel Replacement: 3 단계, 이미지 1/2 HP Officejet Pro 8600 Plus Front Panel Replacement: 3 단계, 이미지 2/2
    • Pull the door-hinge guide to the right to detach its left socket.
    • Lift the door-hinge guide upward and away from the front panel door.
  4. HP Officejet Pro 8600 Plus Front Panel Replacement: 4 단계, 이미지 1/2 HP Officejet Pro 8600 Plus Front Panel Replacement: 4 단계, 이미지 2/2
    • Grab the front panel door close to its hinge on the right side.
    • Pull the front panel door away from the printer toward you.
    • Extra force may be required to pull the door from its hinge.
  5. HP Officejet Pro 8600 Plus Front Panel Replacement: 5 단계, 이미지 1/3 HP Officejet Pro 8600 Plus Front Panel Replacement: 5 단계, 이미지 2/3 HP Officejet Pro 8600 Plus Front Panel Replacement: 5 단계, 이미지 3/3
    • Grab the front panel door close to its two hinges on the left side.
    • Extra force may be required to pull the door from its hinges.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Maegan Betz
회원 가입일: 04/18/18
301 평판
안내서 1개 작성함
Cal Poly, Team S16-G4, Livingston Spring 2018 Cal Poly, Team S16-G4, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S16G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 25
전체 시간: 3,719
