주요 콘텐츠로 건너뛰기
HP Officejet Pro 8600 Plus Power Source Adapter Replacement
필요한 것
  1. HP Officejet Pro 8600 Plus Power Source Adapter Replacement, Power Source Adapter: 1 단계, 이미지 1/2 HP Officejet Pro 8600 Plus Power Source Adapter Replacement, Power Source Adapter: 1 단계, 이미지 2/2
    • Turn the printer so the back is facing you.
    • Put the printer in a vertical position by lifting its right side.
  2. HP Officejet Pro 8600 Plus Power Source Adapter Replacement: 2 단계, 이미지 1/1
    • Remove the two 12mm-T10 Torx screws on the top edge of the printer.
  3. HP Officejet Pro 8600 Plus Power Source Adapter Replacement: 3 단계, 이미지 1/1
    • Rotate the printer clockwise so the bottom of the printer is facing you.
  4. HP Officejet Pro 8600 Plus Power Source Adapter Replacement: 4 단계, 이미지 1/2 HP Officejet Pro 8600 Plus Power Source Adapter Replacement: 4 단계, 이미지 2/2
    • Insert the plastic opening tool underneath the slot on the right that aligns with the edge of the back panel.
    • Insert a second plastic opening tool in the notch lining up with the crease in the back panel.
    • This step requires applying a significant amount of force on the left notch. Don't be alarmed if you hear popping noises.
  5. HP Officejet Pro 8600 Plus Power Source Adapter Replacement: 5 단계, 이미지 1/1
    • Remove the side panel from the printer by lifting upwards toward you.
    • For reassembly, slide the side panel from left to right into place.
  6. HP Officejet Pro 8600 Plus Power Source Adapter Replacement: 6 단계, 이미지 1/3 HP Officejet Pro 8600 Plus Power Source Adapter Replacement: 6 단계, 이미지 2/3 HP Officejet Pro 8600 Plus Power Source Adapter Replacement: 6 단계, 이미지 3/3
    • Rotate the printer to its standard position.
  7. HP Officejet Pro 8600 Plus Power Source Adapter Replacement: 7 단계, 이미지 1/3 HP Officejet Pro 8600 Plus Power Source Adapter Replacement: 7 단계, 이미지 2/3 HP Officejet Pro 8600 Plus Power Source Adapter Replacement: 7 단계, 이미지 3/3
    • Unplug the black wire with the white cap connecting the power supply to the motherboard.
  8. HP Officejet Pro 8600 Plus Power Source Adapter Replacement: 8 단계, 이미지 1/1
    • Remove the two 12mm-T10 Torx screws from the base of the power supply mount.
  9. HP Officejet Pro 8600 Plus Power Source Adapter Replacement: 9 단계, 이미지 1/2 HP Officejet Pro 8600 Plus Power Source Adapter Replacement: 9 단계, 이미지 2/2
    • Place your left hand on the left side of the power supply through the opening in the side of the printer.
  10. HP Officejet Pro 8600 Plus Power Source Adapter Replacement: 10 단계, 이미지 1/3 HP Officejet Pro 8600 Plus Power Source Adapter Replacement: 10 단계, 이미지 2/3 HP Officejet Pro 8600 Plus Power Source Adapter Replacement: 10 단계, 이미지 3/3
    • Grab the base of the cable on the right side of the power supply with your right hand.
    • Remove the power supply by pulling your right hand toward you and pushing your left fingers toward you.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Karissa Roof
회원 가입일: 04/18/18
223 평판
안내서 1개 작성함
Cal Poly, Team S16-G4, Livingston Spring 2018 Cal Poly, Team S16-G4, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S16G4
4 회원들
안내서 10개 작성하였습니다
댓글 3개
I have used this guide to replace the power supply for my Officejet 8715. The only difference is a third screw that needs to be removed to take the cover off.
This is an easy repair.
The real challenge is to find the right replacement part. The power supply is used in various models.
The OEM Number of the power supply is E3E01-60132
I have paid for this spare part less than 30€. Worthwhile as a new printer costs around 300€.
Bernhard Keim - 답글
Does the 8600 P/S fit on the 8620? If not, what is part nr for 8620?
albert venter - 답글
Un peu galère dommage que j'ai pas trouvé se blog avant car a par les visse chiant à défaire c'est bien expliquer après essai du fusibles en porcelaine jus arrive et rien derrière donc merci
coin coin lecanard - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 17
30일 전: 69
전체 시간: 6,183
