주요 콘텐츠로 건너뛰기
HP Officejet Pro 8620 Display Replacement
필요한 것
  1. HP Officejet Pro 8620 Display Replacement, Display: 1 단계, 이미지 1/2 HP Officejet Pro 8620 Display Replacement, Display: 1 단계, 이미지 2/2
    • Place the printer on its back and rotate the display clockwise to gain access to the underside of the display.
  2. HP Officejet Pro 8620 Display Replacement: 2 단계, 이미지 1/3 HP Officejet Pro 8620 Display Replacement: 2 단계, 이미지 2/3 HP Officejet Pro 8620 Display Replacement: 2 단계, 이미지 3/3
    • Locate the control arm on the underside of the display. You will need to detach this to access the screws.
    • Place a finger behind the control arm.
    • Separate the display unit from the control arm by pulling down with your finger and using your other hand to push the display unit up.
    • Removing the control arm takes a moderate amount of force.
  3. HP Officejet Pro 8620 Display Replacement: 3 단계, 이미지 1/3 HP Officejet Pro 8620 Display Replacement: 3 단계, 이미지 2/3 HP Officejet Pro 8620 Display Replacement: 3 단계, 이미지 3/3
    • Remove the four 11mm T9-Torx screws on the underside of the display unit by rotating the screwdriver counter clockwise.
    • Open the display unit to expose the circuit board by separating the back and front panels.
    • Remove the ribbon cable by gently releasing the plastic locking mechanism and pulling the cable away from the circuit board.
  4. HP Officejet Pro 8620 Display Replacement: 4 단계, 이미지 1/2 HP Officejet Pro 8620 Display Replacement: 4 단계, 이미지 2/2
    • Remove the four 7mm T9-Torx screws from the circuit board that are holding the screen in place using a T9-Torx screwdriver and turning counter clockwise.
    • Lift the circuit board/screen panel from the black frame.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Dallas Rocha
회원 가입일: 01/24/18
243 평판
안내서 1개 작성함
Cal Poly, Team S19-G2, Livingston Winter 2018 Cal Poly, Team S19-G2, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S19G2
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 22
전체 시간: 4,957
