주요 콘텐츠로 건너뛰기
HP Officejet Pro 8620 Power Adapter Replacement
필요한 것
  1. HP Officejet Pro 8620 Power Adapter Replacement, Left Panel: 1 단계, 이미지 1/3 HP Officejet Pro 8620 Power Adapter Replacement, Left Panel: 1 단계, 이미지 2/3 HP Officejet Pro 8620 Power Adapter Replacement, Left Panel: 1 단계, 이미지 3/3
    • Turn off the printer and remove the power cable.
    • Remove two 13mm T9 screws using a T9-Torx screwdriver. Turn counterclockwise until the screws are released.
  2. HP Officejet Pro 8620 Power Adapter Replacement: 2 단계, 이미지 1/2 HP Officejet Pro 8620 Power Adapter Replacement: 2 단계, 이미지 2/2
    • Open the front door by placing your finger on the indented groove on the left side of the printer and pulling down
    • This will give you access to the two T9-TORX 13mm screws that need to be removed to release the panel.
  3. HP Officejet Pro 8620 Power Adapter Replacement: 3 단계, 이미지 1/2 HP Officejet Pro 8620 Power Adapter Replacement: 3 단계, 이미지 2/2
    • Remove the two 13mm screws with a T9-TORX screwdriver by turning counter-clockwise (left).
  4. HP Officejet Pro 8620 Power Adapter Replacement: 4 단계, 이미지 1/3 HP Officejet Pro 8620 Power Adapter Replacement: 4 단계, 이미지 2/3 HP Officejet Pro 8620 Power Adapter Replacement: 4 단계, 이미지 3/3
    • Gently remove the left side panel by placing your palm flat against the surface and pulling down.
  5. HP Officejet Pro 8620 Power Adapter Replacement, Power Adapter: 5 단계, 이미지 1/3 HP Officejet Pro 8620 Power Adapter Replacement, Power Adapter: 5 단계, 이미지 2/3 HP Officejet Pro 8620 Power Adapter Replacement, Power Adapter: 5 단계, 이미지 3/3
    • Remove two screws 13mm screws with a T9-Torx screwdriver by rotating them counterclockwise.
  6. HP Officejet Pro 8620 Power Adapter Replacement: 6 단계, 이미지 1/3 HP Officejet Pro 8620 Power Adapter Replacement: 6 단계, 이미지 2/3 HP Officejet Pro 8620 Power Adapter Replacement: 6 단계, 이미지 3/3
    • Unplug the black cable .
    • Move all the cables and wires to the top of the motherboard to allow the power adapter underneath to be removed freely.
  7. HP Officejet Pro 8620 Power Adapter Replacement: 7 단계, 이미지 1/1
    • Gently bend the black ribbon cable.
    • Remove one 8mm T8 screw underneath the ribbon cable by rotating it counterclockwise with a T8 -Torx screwdriver.
    • Take out the black plastic cover and the colored wires connected to it.
    • Now you have cleared a passage for the power adapter to be taken out.
  8. HP Officejet Pro 8620 Power Adapter Replacement: 8 단계, 이미지 1/1
    • Gently pulling out the power adapter.
    • Be careful with all the wires when pulling out the adapter.
결론
Scott
회원 가입일: 01/24/18
593 평판
안내서 3개 작성하였습니다
Cal Poly, Team S19-G2, Livingston Spring 2018 Cal Poly, Team S19-G2, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S19G2
1 회원
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 17
전체 시간: 2,231
