주요 콘텐츠로 건너뛰기
HP Officejet Pro 8620 Power Button Replacement
필요한 것
  1. HP Officejet Pro 8620 Power Button Replacement, Power Button: 1 단계, 이미지 1/3 HP Officejet Pro 8620 Power Button Replacement, Power Button: 1 단계, 이미지 2/3 HP Officejet Pro 8620 Power Button Replacement, Power Button: 1 단계, 이미지 3/3
    • Locate the power button on the bottom left side of the device.
    • Wedge the opening tool into the small gap between the power button panel and printer.
    • Apply pressure on the opening tool and open the power button panel.
    • Gently remove the power button panel assembly from the printer to access the power button.
  2. HP Officejet Pro 8620 Power Button Replacement: 2 단계, 이미지 1/2 HP Officejet Pro 8620 Power Button Replacement: 2 단계, 이미지 2/2
    • Press on the power button from the front of the panel to release it.
  3. HP Officejet Pro 8620 Power Button Replacement: 3 단계, 이미지 1/2 HP Officejet Pro 8620 Power Button Replacement: 3 단계, 이미지 2/2
    • Turn the panel around so you are viewing the back of it.
    • Disconnect the power button from the panel by gently pulling the button out (toward your body).
    • Be careful not to crack the connector of the button panel when pulling the power button
결론
Scott
회원 가입일: 01/24/18
593 평판
안내서 3개 작성하였습니다
Cal Poly, Team S19-G2, Livingston Spring 2018 Cal Poly, Team S19-G2, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S19G2
1 회원
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 28
전체 시간: 2,533
