주요 콘텐츠로 건너뛰기
HP Officejet Pro 8620 Printer Head Replacement
  1. HP Officejet Pro 8620 Printer Head Replacement, Printer Head: 1 단계, 이미지 1/1
    • Open the printer head cover door by pulling the cover door.
    • Power on the printer. This will move the print head to the left so you can access it.
    • Unplug the power cable from the back of the printer.
    • Do not power down the printer using the power button, as this will cause the printhead to move back to the right, making it incaccessible.
  2. HP Officejet Pro 8620 Printer Head Replacement: 2 단계, 이미지 1/2 HP Officejet Pro 8620 Printer Head Replacement: 2 단계, 이미지 2/2
    • Locate the printer head on the left side of the printer.
  3. HP Officejet Pro 8620 Printer Head Replacement: 3 단계, 이미지 1/2 HP Officejet Pro 8620 Printer Head Replacement: 3 단계, 이미지 2/2
    • Pull the white plastic tab on the right of the printhead toward you on an upward swing to unlock the printhead.
  4. HP Officejet Pro 8620 Printer Head Replacement: 4 단계, 이미지 1/2 HP Officejet Pro 8620 Printer Head Replacement: 4 단계, 이미지 2/2
    • Gently pull out the printer head.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Scott
회원 가입일: 01/24/18
593 평판
안내서 3개 작성하였습니다
Cal Poly, Team S19-G2, Livingston Spring 2018 Cal Poly, Team S19-G2, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S19G2
1 회원
안내서 6개 작성하였습니다
댓글 15개
Did not work for me on my HP 8620.
Sam Cauchi - 답글
Do you sell the replacement print head box for the HP Officejet pro 8620?
Do you post to England?
Thanks Pat Trotter
Pat Trotter - 답글
How about always paperjam and printhead just moving by 1 inch
Setiawan Ayooservice - 답글
Replacing easy.
BUT. Can it be repaired? Someone real experience with it?
PS. Of course only as no physical damage from outside and all 4 ink chambers (1) still sealed properly and (2) never have run empty
lbruederlin - 답글
Did not work for me. Followed the instruction and re installed the printhead. Same issue.
abenani2000 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 40
30일 전: 196
전체 시간: 23,859
