주요 콘텐츠로 건너뛰기
HP Officejet Pro 8625 Display Motherboard Replacement
필요한 것
  1. HP Officejet Pro 8625 Display Motherboard Replacement, Display Motherboard: 1 단계, 이미지 1/2 HP Officejet Pro 8625 Display Motherboard Replacement, Display Motherboard: 1 단계, 이미지 2/2
    • Disconnect the display by holding it in place while pulling down on the plastic hinge.
    • Slowly apply more and more force as it does take a lot to separate, do not worry about the hinge or display breaking.
  2. HP Officejet Pro 8625 Display Motherboard Replacement: 2 단계, 이미지 1/3 HP Officejet Pro 8625 Display Motherboard Replacement: 2 단계, 이미지 2/3 HP Officejet Pro 8625 Display Motherboard Replacement: 2 단계, 이미지 3/3
    • Lift the display as high as it will allow to expose the back of the display.
    • Pinch the sides of the cover and pull away from the printer to reveal the connector.
    • Remove the connector by pulling both away from the display and towards the printer.
  3. HP Officejet Pro 8625 Display Motherboard Replacement: 3 단계, 이미지 1/3 HP Officejet Pro 8625 Display Motherboard Replacement: 3 단계, 이미지 2/3 HP Officejet Pro 8625 Display Motherboard Replacement: 3 단계, 이미지 3/3
    • Remove the four 6.2 mm T9 screws from the back of the display.
    • Pull the display assembly up and away from the printer.
  4. HP Officejet Pro 8625 Display Motherboard Replacement: 4 단계, 이미지 1/2 HP Officejet Pro 8625 Display Motherboard Replacement: 4 단계, 이미지 2/2
    • Remove the back cover from the display assembly by pressing down on the point of connection.
    • If you use a plastic spudger for this step, be careful not to brake the plastic as you do not need to use much force to remove the back cover.
  5. HP Officejet Pro 8625 Display Motherboard Replacement: 5 단계, 이미지 1/2 HP Officejet Pro 8625 Display Motherboard Replacement: 5 단계, 이미지 2/2
    • Remove the four 4.8 mm T6 screws from the back of the display motherboard.
  6. HP Officejet Pro 8625 Display Motherboard Replacement: 6 단계, 이미지 1/2 HP Officejet Pro 8625 Display Motherboard Replacement: 6 단계, 이미지 2/2
    • Remove the connection on the front of the display motherboard.
    • Remove the display motherboard.
결론
Daniel
회원 가입일: 10/08/18
289 평판
안내서 2개 작성하였습니다
Cal Poly, Team S13-G3, White Fall 2018 Cal Poly, Team S13-G3, White Fall 2018 회원
CPSU-WHITE-F18S13G3
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 221
