이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Disconnect the display by holding it in place while pulling down on the plastic hinge.
Lift the display as high as it will allow to expose the back of the display.
Pinch the sides of the cover and pull away from the printer to reveal the connector.
Remove the connector by pulling both away from the display and towards the printer.
Remove the four 6.2 mm T9 screws from the back of the display.
Pull the display assembly up and away from the printer.
Remove the back cover from the display assembly by pressing down on the point of connection.
Remove the four 4.8 mm T6 screws from the back of the display motherboard.
Remove the connection on the front of the display motherboard.
Remove the display motherboard.
