주요 콘텐츠로 건너뛰기
HP Officejet Pro 8625 Left Side Panel Replacement
필요한 것
  1. HP Officejet Pro 8625 Left Side Panel Replacement, Left Side Panel: 1 단계, 이미지 1/3 HP Officejet Pro 8625 Left Side Panel Replacement, Left Side Panel: 1 단계, 이미지 2/3 HP Officejet Pro 8625 Left Side Panel Replacement, Left Side Panel: 1 단계, 이미지 3/3
    • Remove the two 11.6 mm T9 screws from the right side of the back of the printer.
  2. HP Officejet Pro 8625 Left Side Panel Replacement: 2 단계, 이미지 1/3 HP Officejet Pro 8625 Left Side Panel Replacement: 2 단계, 이미지 2/3 HP Officejet Pro 8625 Left Side Panel Replacement: 2 단계, 이미지 3/3
    • Pull down the front panel to expose the screws on the front.
    • Remove the one 11.6 mm T9 screw on the left side of the front face.
  3. HP Officejet Pro 8625 Left Side Panel Replacement: 3 단계, 이미지 1/2 HP Officejet Pro 8625 Left Side Panel Replacement: 3 단계, 이미지 2/2
    • Remove the side panel by pushing down and towards the back.
    • This step may be easier if the printer is laid on its side with the left side panel facing up.
결론
Daniel
회원 가입일: 10/08/18
289 평판
안내서 2개 작성하였습니다
Cal Poly, Team S13-G3, White Fall 2018 Cal Poly, Team S13-G3, White Fall 2018 회원
CPSU-WHITE-F18S13G3
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 344
