주요 콘텐츠로 건너뛰기
HP Officejet Pro 8625 Motherboard Replacement
필요한 것
  1. HP Officejet Pro 8625 Motherboard Replacement, Left Side Panel: 1 단계, 이미지 1/3 HP Officejet Pro 8625 Motherboard Replacement, Left Side Panel: 1 단계, 이미지 2/3 HP Officejet Pro 8625 Motherboard Replacement, Left Side Panel: 1 단계, 이미지 3/3
    • Remove the two 11.6 mm T9 screws from the right side of the back of the printer.
  2. HP Officejet Pro 8625 Motherboard Replacement: 2 단계, 이미지 1/3 HP Officejet Pro 8625 Motherboard Replacement: 2 단계, 이미지 2/3 HP Officejet Pro 8625 Motherboard Replacement: 2 단계, 이미지 3/3
    • Pull down the front panel to expose the screws on the front.
    • Remove the one 11.6 mm T9 screw on the left side of the front face.
  3. HP Officejet Pro 8625 Motherboard Replacement: 3 단계, 이미지 1/2 HP Officejet Pro 8625 Motherboard Replacement: 3 단계, 이미지 2/2
    • Remove the side panel by pushing down and towards the back.
    • This step may be easier if the printer is laid on its side with the left side panel facing up.
  4. HP Officejet Pro 8625 Motherboard Replacement, Motherboard: 4 단계, 이미지 1/3 HP Officejet Pro 8625 Motherboard Replacement, Motherboard: 4 단계, 이미지 2/3 HP Officejet Pro 8625 Motherboard Replacement, Motherboard: 4 단계, 이미지 3/3
    • Remove the three 5.3 mm T9 screws from the motherboard.
    • Remove the one 6.7 mm T9 screw from the motherboard.
  5. HP Officejet Pro 8625 Motherboard Replacement: 5 단계, 이미지 1/2 HP Officejet Pro 8625 Motherboard Replacement: 5 단계, 이미지 2/2
    • Remove the connectors from the front and sides of the motherboard by pulling straight away from the connection.
  6. HP Officejet Pro 8625 Motherboard Replacement: 6 단계, 이미지 1/3 HP Officejet Pro 8625 Motherboard Replacement: 6 단계, 이미지 2/3 HP Officejet Pro 8625 Motherboard Replacement: 6 단계, 이미지 3/3
    • Lift the bottom of the motherboard and remove the connectors from the back.
    • Remove the motherboard.
    • There are two white connectors underneath the motherboard, remove them separately.
결론
Cam Engle
회원 가입일: 10/08/18
555 평판
안내서 3개 작성하였습니다
Cal Poly, Team S13-G3, White Fall 2018 Cal Poly, Team S13-G3, White Fall 2018 회원
CPSU-WHITE-F18S13G3
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 521
