주요 콘텐츠로 건너뛰기
HP Officejet Pro 8625 Power Supply Replacement
필요한 것
  1. HP Officejet Pro 8625 Power Supply Replacement, Left Side Panel: 1 단계, 이미지 1/3 HP Officejet Pro 8625 Power Supply Replacement, Left Side Panel: 1 단계, 이미지 2/3 HP Officejet Pro 8625 Power Supply Replacement, Left Side Panel: 1 단계, 이미지 3/3
    • Remove the two 11.6 mm T9 screws from the right side of the back of the printer.
  2. HP Officejet Pro 8625 Power Supply Replacement: 2 단계, 이미지 1/3 HP Officejet Pro 8625 Power Supply Replacement: 2 단계, 이미지 2/3 HP Officejet Pro 8625 Power Supply Replacement: 2 단계, 이미지 3/3
    • Pull down the front panel to expose the screws on the front.
    • Remove the one 11.6 mm T9 screw on the left side of the front face.
  3. HP Officejet Pro 8625 Power Supply Replacement: 3 단계, 이미지 1/2 HP Officejet Pro 8625 Power Supply Replacement: 3 단계, 이미지 2/2
    • Remove the side panel by pushing down and towards the back.
    • This step may be easier if the printer is laid on its side with the left side panel facing up.
  4. HP Officejet Pro 8625 Power Supply Replacement, Power Supply: 4 단계, 이미지 1/3 HP Officejet Pro 8625 Power Supply Replacement, Power Supply: 4 단계, 이미지 2/3 HP Officejet Pro 8625 Power Supply Replacement, Power Supply: 4 단계, 이미지 3/3
    • Remove the the black cable from the bottom of the motherboard by carefully pulling down on the connection.
  5. HP Officejet Pro 8625 Power Supply Replacement: 5 단계, 이미지 1/2 HP Officejet Pro 8625 Power Supply Replacement: 5 단계, 이미지 2/2
    • Remove the two 9.3 mm T9 screws that attach the power supply to the bottom of the printer.
  6. HP Officejet Pro 8625 Power Supply Replacement: 6 단계, 이미지 1/2 HP Officejet Pro 8625 Power Supply Replacement: 6 단계, 이미지 2/2
    • Slide the power supply out of the printer by pulling towards you.
    • Be careful of the wires coming from the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Cole Andrews
회원 가입일: 10/08/18
273 평판
안내서 2개 작성하였습니다
Cal Poly, Team S13-G3, White Fall 2018 Cal Poly, Team S13-G3, White Fall 2018 회원
CPSU-WHITE-F18S13G3
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 11
전체 시간: 488
