주요 콘텐츠로 건너뛰기
HP Officejet Pro 8625 Printhead Replacement
필요한 것
  1. HP Officejet Pro 8625 Printhead Replacement, Left Side Panel: 1 단계, 이미지 1/3 HP Officejet Pro 8625 Printhead Replacement, Left Side Panel: 1 단계, 이미지 2/3 HP Officejet Pro 8625 Printhead Replacement, Left Side Panel: 1 단계, 이미지 3/3
    • Remove the two 11.6 mm T9 screws from the right side of the back of the printer.
  2. HP Officejet Pro 8625 Printhead Replacement: 2 단계, 이미지 1/3 HP Officejet Pro 8625 Printhead Replacement: 2 단계, 이미지 2/3 HP Officejet Pro 8625 Printhead Replacement: 2 단계, 이미지 3/3
    • Pull down the front panel to expose the screws on the front.
    • Remove the one 11.6 mm T9 screw on the left side of the front face.
  3. HP Officejet Pro 8625 Printhead Replacement: 3 단계, 이미지 1/2 HP Officejet Pro 8625 Printhead Replacement: 3 단계, 이미지 2/2
    • Remove the side panel by pushing down and towards the back.
    • This step may be easier if the printer is laid on its side with the left side panel facing up.
  4. HP Officejet Pro 8625 Printhead Replacement, Printhead: 4 단계, 이미지 1/2 HP Officejet Pro 8625 Printhead Replacement, Printhead: 4 단계, 이미지 2/2
    • Remove the one 5.3 mm T9 screw.
  5. HP Officejet Pro 8625 Printhead Replacement: 5 단계, 이미지 1/2 HP Officejet Pro 8625 Printhead Replacement: 5 단계, 이미지 2/2
    • Remove the four connectors from the top of the motherboard.
  6. HP Officejet Pro 8625 Printhead Replacement: 6 단계, 이미지 1/2 HP Officejet Pro 8625 Printhead Replacement: 6 단계, 이미지 2/2
    • Remove the three 11.6 mm T9 screws from the top, back of the printer.
    • Remove the one 12.1 mm T9 screw from the top, back of the printer.
  7. HP Officejet Pro 8625 Printhead Replacement: 7 단계, 이미지 1/2 HP Officejet Pro 8625 Printhead Replacement: 7 단계, 이미지 2/2
    • Remove the 11.6mm T9 screw from the top left of the front of the printer.
  8. HP Officejet Pro 8625 Printhead Replacement: 8 단계, 이미지 1/1
    • Disconnect the display by pulling down on the plastic hinge.
    • Gradually apply more force to the hinge and don't worry about the hinge or display breaking.
  9. HP Officejet Pro 8625 Printhead Replacement: 9 단계, 이미지 1/3 HP Officejet Pro 8625 Printhead Replacement: 9 단계, 이미지 2/3 HP Officejet Pro 8625 Printhead Replacement: 9 단계, 이미지 3/3
    • Lift the display as high as it will allow to expose the back of the display.
    • Remove the connector by pinching the sides and pulling away from the printer.
    • Remove the connector by pulling both away from the display and towards the printer.
  10. HP Officejet Pro 8625 Printhead Replacement: 10 단계, 이미지 1/2 HP Officejet Pro 8625 Printhead Replacement: 10 단계, 이미지 2/2
    • Remove the two 11.6 mm T9 screws from beneath the display.
  11. HP Officejet Pro 8625 Printhead Replacement: 11 단계, 이미지 1/1
    • Remove the top of the printer by lifting it from both sides.
  12. HP Officejet Pro 8625 Printhead Replacement: 12 단계, 이미지 1/3 HP Officejet Pro 8625 Printhead Replacement: 12 단계, 이미지 2/3 HP Officejet Pro 8625 Printhead Replacement: 12 단계, 이미지 3/3
    • Locate the printhead on the right side of the printer.
    • Pull the white tab on the right side of the printhead up, by pushing on the side of the printer a little bit.
    • Remove the printhead by lifting it out of the housing.
    You need to tell HOW to remove connectors - pull up or out etc>
    Richard Grassi - 답글
결론
다른 6명이 해당 안내서를 완성하였습니다.
Cam Engle
회원 가입일: 10/08/18
531 평판
안내서 3개 작성하였습니다
Cal Poly, Team S13-G3, White Fall 2018 Cal Poly, Team S13-G3, White Fall 2018 회원
CPSU-WHITE-F18S13G3
3 회원들
안내서 14개 작성하였습니다
댓글 5개
This printhead is normally user replaceable.
No screwdrivers are required.
This video is for an 8600, but the process is the same.
https://www.youtube.com/watch?v=i-IluLvF...
Andy - 답글
I used these instructions to repair the guide ribbon for the print head. It had come off after a sheet of high tack labels got jammed in the printer. Just saved myself from having to buy a new printer! Thanks!!!
Robert de Salazar - 답글
12 steps not necessary. Just open the front (like changing ink) and lift the grey lever referenced in step 12, then remove the head from the carriage.
bwaaronj - 답글
Correct. So easy.
hinz -
BWAARONJ, I did exactly what you suggested in my 8625 three times! Now my printer is in pieces and parts, and I cannot get the printhead to release from the right side of the housing. I was very meticulous in making an effort to correct this problem, but, alas, it appears I will have to get a new printer!
Shelia Guy Bozeman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 72
전체 시간: 7,740
