주요 콘텐츠로 건너뛰기
HP Omen 15-5002xx Keyboard Replacement
필요한 것
  1. HP Omen 15-5002xx Keyboard Replacement, Back Cover: 1 단계, 이미지 1/2 HP Omen 15-5002xx Keyboard Replacement, Back Cover: 1 단계, 이미지 2/2
    • Flip the laptop upside down so the backside is facing up.
    • Use a spudger or your fingers to remove the thin rubber strips that are attached from the edges of the laptop.
    • Remember where each thin rubber came from and set them off to the side.
    • Unscrew all 14 screw with the J00 JIS Screwdriver.
  2. HP Omen 15-5002xx Keyboard Replacement, Battery: 2 단계, 이미지 1/1
    • Open the case slowly from opposite sides of the laptop.
    • Use the J00 JIS screwdriver to remove eight screws securing the battery.
  3. HP Omen 15-5002xx Keyboard Replacement: 3 단계, 이미지 1/2 HP Omen 15-5002xx Keyboard Replacement: 3 단계, 이미지 2/2
    • Carefully remove the battery connector that is attached to the motherboard by slowly sliding it towards the battery with two fingers.
    • Remove the battery by lifting it up and out.
  4. HP Omen 15-5002xx Keyboard Replacement, Fan: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Flathead 1.5 mm Screwdriver
    $5.49
    구매
    • Remove the twelve big screws with the J00 JIS screwdriver.
    • Remove all eight small screws with the 1.5 flathead screwdriver.
  5. HP Omen 15-5002xx Keyboard Replacement: 5 단계, 이미지 1/2 HP Omen 15-5002xx Keyboard Replacement: 5 단계, 이미지 2/2
    • Carefully detach the fan connector that is attached to the motherboard by slowly sliding the connector out with two fingers.
    • Remove the battery carefully.
  6. HP Omen 15-5002xx Keyboard Replacement, Wi-Fi Card: 6 단계, 이미지 1/1
    • Use the Phillips #00 to remove one screw securing the Wi-Fi Card.
  7. HP Omen 15-5002xx Keyboard Replacement: 7 단계, 이미지 1/1
    • Carefully remove the Wi-Fi Card by slowly sliding the card sideways away from the motherboard.
  8. HP Omen 15-5002xx Keyboard Replacement, Motherboard: 8 단계, 이미지 1/1
    이 단계에 사용된 도구:
    $5.49
    구매
    • Use the 1.5 flathead screwdriver and remove the twelve screws from the motherboard.
  9. HP Omen 15-5002xx Keyboard Replacement: 9 단계, 이미지 1/3 HP Omen 15-5002xx Keyboard Replacement: 9 단계, 이미지 2/3 HP Omen 15-5002xx Keyboard Replacement: 9 단계, 이미지 3/3
    • Disconnect the four cables attached to the motherboard.
  10. HP Omen 15-5002xx Keyboard Replacement: 10 단계, 이미지 1/2 HP Omen 15-5002xx Keyboard Replacement: 10 단계, 이미지 2/2
    • Disconnect the remaining four connectors from the motherboard.
    • Remove the motherboard.
  11. HP Omen 15-5002xx Keyboard Replacement, Keyboard: 11 단계, 이미지 1/1
    이 단계에 사용된 도구:
    $5.49
    구매
    • Remove all 51 screws using the 1.5 mm flathead screwdriver from the underside of the keyboard.
    • All necessary screws are numbered from 1-51 on the side of each screw hole.
  12. HP Omen 15-5002xx Keyboard Replacement: 12 단계, 이미지 1/2 HP Omen 15-5002xx Keyboard Replacement: 12 단계, 이미지 2/2
    • Slowly pull the electricity tape off of the computer.
    • You are able to replace the electricity tape or keep the tape attached with the wire.
  13. HP Omen 15-5002xx Keyboard Replacement: 13 단계, 이미지 1/2 HP Omen 15-5002xx Keyboard Replacement: 13 단계, 이미지 2/2
    • With two hands, lift the keyboards from the sides.
결론
Hassan Isse
회원 가입일: 09/01/21
97 평판
안내서 1개 작성함
Gateway, Team 1-1, Saknee Fall 2021 Gateway, Team 1-1, Saknee Fall 2021 회원
GCC-SAKNEE-F21S1G1
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 11
30일 전: 43
전체 시간: 1,222
