주요 콘텐츠로 건너뛰기
HP Omen 15-5002xx Wi-Fi Card Replacement
필요한 것
  1. HP Omen 15-5002xx Wi-Fi Card Replacement, Back Cover: 1 단계, 이미지 1/2 HP Omen 15-5002xx Wi-Fi Card Replacement, Back Cover: 1 단계, 이미지 2/2
    • Flip the laptop upside down so the backside is facing up.
    • Use a spudger or your fingers to remove the thin rubber strips that are attached from the edges of the laptop.
    • Remember where each thin rubber came from and set them off to the side.
    • Unscrew all 14 screw with the J00 JIS Screwdriver.
  2. HP Omen 15-5002xx Wi-Fi Card Replacement, Wi-Fi Card: 2 단계, 이미지 1/1
    • Use the Phillips #00 to remove one screw securing the Wi-Fi Card.
  3. HP Omen 15-5002xx Wi-Fi Card Replacement: 3 단계, 이미지 1/1
    • Carefully remove the Wi-Fi Card by slowly sliding the card sideways away from the motherboard.
결론
Eduardo Arellano
회원 가입일: 09/01/21
621 평판
안내서 5개 작성하였습니다
Gateway, Team 1-1, Saknee Fall 2021 Gateway, Team 1-1, Saknee Fall 2021 회원
GCC-SAKNEE-F21S1G1
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 20
전체 시간: 464
