주요 콘텐츠로 건너뛰기
HP Omen 15-ax200ne Hard Drive Replacement
필요한 것
  1. HP Omen 15-ax200ne Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Fully power off the laptop.
    • If you are unsure that your laptop is in hibernation mode, turn the computer off from the start menu.
    • Unplug charging cable and any external devices.
  2. HP Omen 15-ax200ne Hard Drive Replacement: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Position the laptop upside down on a flat and clean surface.
    • Make sure to stay away from static discharge or wear an anti-static wrist strap.
    • Remove the two Phillips M2x5.0 screws located at the top left and top right of the laptop (circled in red).
    • Remove the eight M2.5x6.0 (circled in orange).
  3. HP Omen 15-ax200ne Hard Drive Replacement: 3 단계, 이미지 1/2 HP Omen 15-ax200ne Hard Drive Replacement: 3 단계, 이미지 2/2
    • Keep in mind, there are three internal clips by the battery area.
    • Slide the nylon opening tool around the edge of the base enclosure, releasing the three clips by the battery area.
    • Continue to slide the nylon opening tool around the edges of the base enclosure, doing so while loosen the cover.
  4. HP Omen 15-ax200ne Hard Drive Replacement: 4 단계, 이미지 1/2 HP Omen 15-ax200ne Hard Drive Replacement: 4 단계, 이미지 2/2
    • After successfully loosening the base enclosure, and removing it. You will be left with an exposed motherboard.
  5. HP Omen 15-ax200ne Hard Drive Replacement: 5 단계, 이미지 1/3 HP Omen 15-ax200ne Hard Drive Replacement: 5 단계, 이미지 2/3 HP Omen 15-ax200ne Hard Drive Replacement: 5 단계, 이미지 3/3
    • Unplug the battery from the motherboard.
    • Release the battery cable from the routing channel to reveal the screws beneath.
  6. HP Omen 15-ax200ne Hard Drive Replacement: 6 단계, 이미지 1/3 HP Omen 15-ax200ne Hard Drive Replacement: 6 단계, 이미지 2/3 HP Omen 15-ax200ne Hard Drive Replacement: 6 단계, 이미지 3/3
    • Remove the four 2x5 screws using the Phillips screwdriver.
    • Slide the battery out of its space to remove it from the computer.
  7. HP Omen 15-ax200ne Hard Drive Replacement: 8 단계, 이미지 1/3 HP Omen 15-ax200ne Hard Drive Replacement: 8 단계, 이미지 2/3 HP Omen 15-ax200ne Hard Drive Replacement: 8 단계, 이미지 3/3
    • Disconnect the clip attaching the hard drive cable to the motherboard.
    • Be careful when disconnecting this clip, as it is very delicate.
    • Use your fingers or a spudger to disconnect the cable. Do not use a screwdriver for the job. It could cause damage.
    • Slide the hard drive out horizontally.
  8. HP Omen 15-ax200ne Hard Drive Replacement: 9 단계, 이미지 1/1
    • Disassemble the hard drive by removing the connector and the side brackets.
  9. HP Omen 15-ax200ne Hard Drive Replacement: 10 단계, 이미지 1/2 HP Omen 15-ax200ne Hard Drive Replacement: 10 단계, 이미지 2/2
    • Reattach the side brackets and the hard drive connector.
  10. HP Omen 15-ax200ne Hard Drive Replacement: 11 단계, 이미지 1/2 HP Omen 15-ax200ne Hard Drive Replacement: 11 단계, 이미지 2/2
    • Slide the hard drive back to the original spot.
    • Reclip the hard drive to the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Khaled Hamdan
회원 가입일: 01/14/21
193 평판
안내서 1개 작성함
York University, Team S2-G8, O'Regan Winter 2021 York University, Team S2-G8, O'Regan Winter 2021 회원
YORK-O'REGAN-W21S2G8
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 15
30일 전: 58
전체 시간: 2,591
