주요 콘텐츠로 건너뛰기
HP Omen 15-ax243dx Hard-Drive Replacement
필요한 것
  1. HP Omen 15-ax243dx Hard-Drive Replacement, Battery: 1 단계, 이미지 1/2 HP Omen 15-ax243dx Hard-Drive Replacement, Battery: 1 단계, 이미지 2/2
    • The rear panel is secured by 10 screws. Using a #00 Phillips Screwdriver, remove the ten 1.2 mm screws.
    • The screwdriver should be inserted at the same angle as the screws.
    • Be sure to keep track of the screws and where they came from. Some only fit in to one spot.
  2. HP Omen 15-ax243dx Hard-Drive Replacement: 2 단계, 이미지 1/2 HP Omen 15-ax243dx Hard-Drive Replacement: 2 단계, 이미지 2/2
    • Insert a plastic opening tool between the rear panel and the top case. Pry the opening tool upwards to separate the top case from the bottom case.
    • Slide the opening tool along the case perimeter to loosen the bottom case.
    • Gently pull the bottom case away from the laptop.
  3. HP Omen 15-ax243dx Hard-Drive Replacement: 3 단계, 이미지 1/2 HP Omen 15-ax243dx Hard-Drive Replacement: 3 단계, 이미지 2/2
    • Remove the four 1.2 mm Phillips #00 screws around the battery.
  4. HP Omen 15-ax243dx Hard-Drive Replacement: 4 단계, 이미지 1/2 HP Omen 15-ax243dx Hard-Drive Replacement: 4 단계, 이미지 2/2
    • Pull the battery cable out from its motherboard socket.
    • Pull parallel to the motherboard, not straight up.
    • Remove the battery.
    • Disconnect the power cord from the battery and transfer it to your replacement battery.
  5. HP Omen 15-ax243dx Hard-Drive Replacement, Hard-Drive: 5 단계, 이미지 1/1
    • After the battery is removed, the hard drive will be easier to access in the top right hand corner.
  6. HP Omen 15-ax243dx Hard-Drive Replacement: 6 단계, 이미지 1/3 HP Omen 15-ax243dx Hard-Drive Replacement: 6 단계, 이미지 2/3 HP Omen 15-ax243dx Hard-Drive Replacement: 6 단계, 이미지 3/3
    • With a opening tool, flip open the switch that locks in the hard drive ribbon cable into the device.
    • When lifting the cable out, lift straight up and out to prevent damage to the connector or cable.
  7. HP Omen 15-ax243dx Hard-Drive Replacement: 7 단계, 이미지 1/1
    • Lift the hard drive up to remove from the device
  8. HP Omen 15-ax243dx Hard-Drive Replacement: 8 단계, 이미지 1/3 HP Omen 15-ax243dx Hard-Drive Replacement: 8 단계, 이미지 2/3 HP Omen 15-ax243dx Hard-Drive Replacement: 8 단계, 이미지 3/3
    • Remove the rubber guards on the side of the hard drive.
    • Gently pull the plastic connector out from the hard drive.
    • The hard drive can now be disposed of if needed.
    • Save the guards and connectors from this hard drive, they will be used on the replacement part.
결론
다른 3명이 해당 안내서를 완성하였습니다.
vangnam
회원 가입일: 10/19/17
594 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S6-G7, Rockett Fall 2017 UMass Dartmouth, Team S6-G7, Rockett Fall 2017 회원
UMASSD-ROCKETT-F17S6G7
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 55
전체 시간: 8,320
