주요 콘텐츠로 건너뛰기
HP Omen 15-ax243dx Ventilation Fans Replacement
필요한 것
  1. HP Omen 15-ax243dx Ventilation Fans Replacement, Battery: 1 단계, 이미지 1/2 HP Omen 15-ax243dx Ventilation Fans Replacement, Battery: 1 단계, 이미지 2/2
    • The rear panel is secured by 10 screws. Using a #00 Phillips Screwdriver, remove the ten 1.2 mm screws.
    • The screwdriver should be inserted at the same angle as the screws.
    • Be sure to keep track of the screws and where they came from. Some only fit in to one spot.
  2. HP Omen 15-ax243dx Ventilation Fans Replacement: 2 단계, 이미지 1/2 HP Omen 15-ax243dx Ventilation Fans Replacement: 2 단계, 이미지 2/2
    • Insert a plastic opening tool between the rear panel and the top case. Pry the opening tool upwards to separate the top case from the bottom case.
    • Slide the opening tool along the case perimeter to loosen the bottom case.
    • Gently pull the bottom case away from the laptop.
  3. HP Omen 15-ax243dx Ventilation Fans Replacement: 3 단계, 이미지 1/2 HP Omen 15-ax243dx Ventilation Fans Replacement: 3 단계, 이미지 2/2
    • Remove the four 1.2 mm Phillips #00 screws around the battery.
  4. HP Omen 15-ax243dx Ventilation Fans Replacement: 4 단계, 이미지 1/2 HP Omen 15-ax243dx Ventilation Fans Replacement: 4 단계, 이미지 2/2
    • Pull the battery cable out from its motherboard socket.
    • Pull parallel to the motherboard, not straight up.
    • Remove the battery.
    • Disconnect the power cord from the battery and transfer it to your replacement battery.
  5. HP Omen 15-ax243dx Ventilation Fans Replacement, Ventilation Fans: 5 단계, 이미지 1/1
    • The two ventilation fans are secured with the system by 5 screws. Unscrew these five 1.2 mm screws using the Phillips #0 screwdriver.
    • When removing the screws, use a magnetic screwdriver to prevent the screws from falling behind the motherboard
  6. HP Omen 15-ax243dx Ventilation Fans Replacement: 6 단계, 이미지 1/2 HP Omen 15-ax243dx Ventilation Fans Replacement: 6 단계, 이미지 2/2
    • After removing all 5 screws, the fans are still connected with the system through 2 cables.
    • Carefully pull the fan cables out of the connectors on the motherboard.
    • Be cautious when pulling by the wires, this can permanently damage the fans beyond repair.
  7. HP Omen 15-ax243dx Ventilation Fans Replacement: 7 단계, 이미지 1/1
    • The fans can now be removed from the device.
결론
다른 4명이 해당 안내서를 완성하였습니다.
vangnam
회원 가입일: 10/19/17
594 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S6-G7, Rockett Fall 2017 UMass Dartmouth, Team S6-G7, Rockett Fall 2017 회원
UMASSD-ROCKETT-F17S6G7
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 20
전체 시간: 5,622
