주요 콘텐츠로 건너뛰기
HP Omni 10 Speaker Replacement
필요한 것
  1. HP Omni 10  Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the back cover from the tablet.
    • The cover is securely fastened to the device and may be difficult to remove.
  2. HP Omni 10  Speaker Replacement: 2 단계, 이미지 1/1
    • Push the black plastic security flaps into an upward position.
    • Lift the small tab on the security strips up and peel them across the battery. They will be attached via adhesive.
    • Lift the tab on the strip up and pull it across the battery.
    • The orange strip does not fully detach from the tablet like the other three. It will only detach from one side.
  3. HP Omni 10  Speaker Replacement: 3 단계, 이미지 1/1
    • Unscrew the ten 3.3 mm screws securing the battery using a 00 Phillip's head screwdriver.
  4. HP Omni 10  Speaker Replacement: 4 단계, 이미지 1/2 HP Omni 10  Speaker Replacement: 4 단계, 이미지 2/2
    • Unhook the cord from the edge of the battery.
    • Pull the wire circuit out and down.
  5. HP Omni 10  Speaker Replacement: 5 단계, 이미지 1/2 HP Omni 10  Speaker Replacement: 5 단계, 이미지 2/2
    • Lift the battery up by its edges and remove it carefully. There will be adhesive holding the battery down.
  6. HP Omni 10  Speaker Replacement, Micro Card Reader: 6 단계, 이미지 1/1
    • Unscrew the two 3.3 mm screws using a 00 Phillip's head screwdriver.
  7. HP Omni 10  Speaker Replacement: 7 단계, 이미지 1/1
    • Lift and remove micro card reader board.
  8. HP Omni 10  Speaker Replacement, Speaker: 8 단계, 이미지 1/1
    • Unscrew the four 3.3 mm screws using a 00 Phillip's head screwdriver.
  9. HP Omni 10  Speaker Replacement: 9 단계, 이미지 1/2 HP Omni 10  Speaker Replacement: 9 단계, 이미지 2/2
    • Pull the black and white wire connector up to disconnect it.
  10. HP Omni 10  Speaker Replacement: 10 단계, 이미지 1/2 HP Omni 10  Speaker Replacement: 10 단계, 이미지 2/2
    • Pull the red and black wire connector up to disconnect it.
  11. HP Omni 10  Speaker Replacement: 11 단계, 이미지 1/1
    • Lift the speaker set out of their sockets.
    • The speakers will also be attached via adhesive. They may be difficult to remove by hand.
  12. HP Omni 10  Speaker Replacement: 12 단계, 이미지 1/1
    • Unhook the left speaker's connector wire to fully remove it from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alex Miller
회원 가입일: 10/11/16
345 평판
안내서 5개 작성하였습니다
USF Tampa, Team 1-1, Leahy Fall 2016 USF Tampa, Team 1-1, Leahy Fall 2016 회원
USFT-LEAHY-F16S1G1
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
its order when i will get it please candly I request
Abdul Raheem - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 9
전체 시간: 591
