주요 콘텐츠로 건너뛰기
HP Omni 10 Micro Card Reader Board Replacement
필요한 것
  1. HP Omni 10 Micro Card Reader Board Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the back cover from the tablet.
    • The cover is securely fastened to the device and may be difficult to remove.
  2. HP Omni 10 Micro Card Reader Board Replacement: 2 단계, 이미지 1/1
    • Push the black plastic security flaps into an upward position.
    • Lift the small tab on the security strips up and peel them across the battery. They will be attached via adhesive.
    • Lift the tab on the strip up and pull it across the battery.
    • The orange strip does not fully detach from the tablet like the other three. It will only detach from one side.
  3. HP Omni 10 Micro Card Reader Board Replacement: 3 단계, 이미지 1/1
    • Unscrew the ten 3.3 mm screws securing the battery using a 00 Phillip's head screwdriver.
  4. HP Omni 10 Micro Card Reader Board Replacement: 4 단계, 이미지 1/2 HP Omni 10 Micro Card Reader Board Replacement: 4 단계, 이미지 2/2
    • Unhook the cord from the edge of the battery.
    • Pull the wire circuit out and down.
  5. HP Omni 10 Micro Card Reader Board Replacement: 5 단계, 이미지 1/2 HP Omni 10 Micro Card Reader Board Replacement: 5 단계, 이미지 2/2
    • Lift the battery up by its edges and remove it carefully. There will be adhesive holding the battery down.
  6. HP Omni 10 Micro Card Reader Board Replacement, Micro Card Reader: 6 단계, 이미지 1/1
    • Unscrew the two 3.3 mm screws using a 00 Phillip's head screwdriver.
  7. HP Omni 10 Micro Card Reader Board Replacement: 7 단계, 이미지 1/1
    • Lift and remove micro card reader board.
결론
Alex Miller
회원 가입일: 10/11/16
345 평판
안내서 5개 작성하였습니다
USF Tampa, Team 1-1, Leahy Fall 2016 USF Tampa, Team 1-1, Leahy Fall 2016 회원
USFT-LEAHY-F16S1G1
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 516
