이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Grasp the scanner lid cover from the front of the device and lift lid all the way up until it stands on its own.
With two hands, grasp the lid on both sides near the hinges and lift straight up to release the lid from each hinge.
Once you have removed the scanner lid, locate the finger notch on inside the top left half of the bezel (control) panel.
Place your index finger in the notch and lift up to unsnap the panel.
Set panel cover aside.
From the front of the printer, remove the button panel by pulling it towards you while slightly lifting it up.
Disconnect the white ribbon cable by grasping it between your thumb and index finger.
Gently pull to release the ribbon from the green circuit board
Next, use the flat end of a spudger to pry loose the flat ribbon computer cable by the plastic connection end and carefully separate it from the prongs on the button panel.
The entire button panel should now be completely disconnected from the printer.
Lay the panel on a flat surface with the backside facing up.
Using a T9 torx screwdriver, remove all six 0.7 cm silver screws from the off-white plastic panel.
Gently lift the button panel off the plastic backing with rubber button mat.
Insert your new button panel. To reassemble your printer, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
