주요 콘텐츠로 건너뛰기
HP PSC 2355 Reflective Document Mat Replacement
필요한 것
  1. HP PSC 2355 Reflective Document Mat Replacement, Scanner Lid: 1 단계, 이미지 1개 중 1개
    • Grasp the scanner lid cover from the front of the device and lift lid all the way up until it stands on its own.
  2. HP PSC 2355 Reflective Document Mat Replacement: 2 단계, 이미지 1개 중 1개
    • With two hands, grasp the lid on both sides near the hinges and lift straight up to release the lid from each hinge.
  3. HP PSC 2355 Reflective Document Mat Replacement, Reflective Document Mat: 3 단계, 이미지 1개 중 1개
    • Once the lid has been removed, lay it on a flat surface with the white mat facing up.
    • Using the flat end of a plastic spudger, pry the mat off at one of the front corners. Do this again for the other front corner.
  4. HP PSC 2355 Reflective Document Mat Replacement: 4 단계, 이미지 2개 중 1개 HP PSC 2355 Reflective Document Mat Replacement: 4 단계, 이미지 2개 중 2개
    • Once both front corners have been released from the plastic clasps the rest of the mat should easily lift off.
    • Recycle or discard the damaged mat.
결론
작성자
3다른 기여자 명과 함께
Amber Gabaldon
회원 가입일: 01/28/14
343 평판
안내서 3개를 작성함
New Mexico State, Team 1-4, Sheppard Spring 2014 New Mexico State, Team 1-4, Sheppard Spring 2014 회원
NMSU-SHEPPARD-S14S1G4
3 회원들
안내서 4개를 작성함
2가이드 댓글
Would a piece of poster board work for a reflective mat?
Karl Dickinson - 답글
I don’t think poster board would work because I don’t think it’s reflective enough.
Patricia -
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 15
전체 시간: 909
