주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP PSC 2355 Scanner Glass Replacement
필요한 것
  1. HP PSC 2355 Scanner Glass Replacement, Scanner Lid: 1 단계, 이미지 1개 중 1개
    • Grasp the scanner lid cover from the front of the device and lift lid all the way up until it stands on its own.
    댓글 쓰기
  2. HP PSC 2355 Scanner Glass Replacement: 2 단계, 이미지 1개 중 1개
    • With two hands, grasp the lid on both sides near the hinges and lift straight up to release the lid from each hinge.
    댓글 쓰기
  3. HP PSC 2355 Scanner Glass Replacement, Scanner Glass: 3 단계, 이미지 2개 중 1개 HP PSC 2355 Scanner Glass Replacement, Scanner Glass: 3 단계, 이미지 2개 중 2개
    • Locate the finger notch on the inside top left half of the bezel (control) panel cover.
    • Place your index finger in the notch and lift up to unsnap the panel.
    • Set the panel cover aside.
    댓글 쓰기
  4. HP PSC 2355 Scanner Glass Replacement: 4 단계, 이미지 1개 중 1개
    • Use a T9 Torx screwdriver to remove the 9 mm screw.
    댓글 쓰기
  5. HP PSC 2355 Scanner Glass Replacement: 5 단계, 이미지 1개 중 1개
    • From the front of the printer, remove the button panel by pulling it towards you while slightly lifting it up.
    댓글 쓰기
  6. HP PSC 2355 Scanner Glass Replacement: 6 단계, 이미지 2개 중 1개 HP PSC 2355 Scanner Glass Replacement: 6 단계, 이미지 2개 중 2개
    • Disconnect the white ribbon cable by grasping it between your thumb and forefinger.
    • Gently pull to release the ribbon from the green circuit board.
    댓글 쓰기
  7. HP PSC 2355 Scanner Glass Replacement: 7 단계, 이미지 1개 중 1개
    • Next, use a spudger to pry the flat ribbon computer cable by the plastic connection end loose. Carefully separate it from the prongs on the button panel.
    • Now the whole button should be completely disconnected from the printer.
    • Set button panel aside.
    댓글 쓰기
  8. HP PSC 2355 Scanner Glass Replacement: 8 단계, 이미지 1개 중 1개
    • Use the T9 Torx screwdriver to remove the seven 9 mm screws on the top plastic frame around the glass.
    댓글 쓰기
  9. HP PSC 2355 Scanner Glass Replacement: 9 단계, 이미지 1개 중 1개
    • From the back of the printer, locate the two large plastic tabs as shown.
    • With your index fingers underneath each tab, gently and simultaneously pull the tabs towards you and upwards to release the tabs from the plastic clasps behind them.
    • Remove the whole plastic frame that holds the glass.
    댓글 쓰기
  10. HP PSC 2355 Scanner Glass Replacement: 10 단계, 이미지 2개 중 1개 HP PSC 2355 Scanner Glass Replacement: 10 단계, 이미지 2개 중 2개
    • Gently lift the glass/plastic bed from the edge on the side opposite of the button/control panel section.
    • As shown in the second image, gently lift the glass pane up so that it is above the plastic tab that holds it into place.
    댓글 쓰기
  11. HP PSC 2355 Scanner Glass Replacement: 11 단계, 이미지 1개 중 1개
    • Proceed to slide the glass pane out and over the plastic tab to remove it completely from the plastic bed.
    • Replace the glass with your new glass pane. To fully reassemble the printer, follow these instructions in reverse order.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Amber Gabaldon
회원 가입일: 01/28/14
343 평판
안내서 3개를 작성함
New Mexico State, Team 1-4, Sheppard Spring 2014 New Mexico State, Team 1-4, Sheppard Spring 2014 회원
NMSU-SHEPPARD-S14S1G4
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 37
전체 시간: 1,254
