주요 콘텐츠로 건너뛰기
Replacing the Carriage in the Photosmart All In One Printer
필요한 것
  1. Replacing the Carriage in the Photosmart All In One Printer, Remove Back Panel: 1 단계, 이미지 1/1
    • Remove the back panel by inserting your fingers into the indentations next to the tabs. Press the tabs inward towards each other while pulling the back panel toward you.
  2. Replacing the Carriage in the Photosmart All In One Printer, Remove Inner Back Pannel: 2 단계, 이미지 1/2 Replacing the Carriage in the Photosmart All In One Printer, Remove Inner Back Pannel: 2 단계, 이미지 2/2
    • Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel.
  3. Replacing the Carriage in the Photosmart All In One Printer, Remove Upper Portion: 3 단계, 이미지 1/2 Replacing the Carriage in the Photosmart All In One Printer, Remove Upper Portion: 3 단계, 이미지 2/2
    • Press down on the two plastic hinges to remove the upper portion of printer.
    The two plastic hinges WON’T PRESS DOWN in order to release them from their housing and lift away the top. I am even resorting to wedging a very thin flat headed screwdriver in on top of the hinge to see if this makes a difference but nothing will budge.
    Maeshowie - 답글
    Further to my first comment, the hinge in the diagram looks slightly different to the ones on the rear of my printer in that the diagram ones look as if they WILL press down, finger force, to release the top.
    I’ve given up and am putting it all back together again. Must now look to see if I can send this printer to someone who knows what they are doing.
    Maeshowie - 답글
    Third and last comment. I tried one last time to release the top, pressed down on the hinge - and it snapped off. This one to the dump and online to buy a new one.
    Maeshowie - 답글
  4. Replacing the Carriage in the Photosmart All In One Printer, Unplug Speaker Wire: 4 단계, 이미지 1/1
    • Grasp the plastic plug on the end of the speaker wire, then gently pull the plug away from the printer until the wire is removed.
  5. Replacing the Carriage in the Photosmart All In One Printer, Removing Scanner Tray: 5 단계, 이미지 1/2 Replacing the Carriage in the Photosmart All In One Printer, Removing Scanner Tray: 5 단계, 이미지 2/2
    • Rotate the printer so the paper tray is facing towards you.
    • Gently lift the scanner tray up and away from the printer.
    • Press the gray plastic tabs inward to release the tabs from the printer.
  6. Replacing the Carriage in the Photosmart All In One Printer, Removing Scanner Tray - cont.: 6 단계, 이미지 1/1
    • Returning to the back of the printer, remove the scanner from the back hinges.
    • With pressure applied, the scanner will detach easily.
    It would be easer to do steps 7 & 8 before step 6.
    Richard Scott - 답글
  7. Replacing the Carriage in the Photosmart All In One Printer: 7 단계, 이미지 1/1
    • Gently grasp and unplug the two white ribbon cables from the printer body.
    • Be sure to grasp the cable at the connector and not to pull on the wires themselves.
  8. Replacing the Carriage in the Photosmart All In One Printer: 8 단계, 이미지 1/1
    • Unplug the white plastic multi-wire connector (with orange, black, red, and brown wires) from it's port.
    • Be sure to grasp the white connector and not to pull on the wires themselves.
  9. Replacing the Carriage in the Photosmart All In One Printer, Detaching the Scanner Tray: 9 단계, 이미지 1/1
    • Detach the scanner tray from the printer by lifting the scanner tray off the printer body.
    But how do you get to the inside of scaner?
    R S V P Urgent
    Paul D
    pauldaley08 - 답글
    As from N0 9 Done thus far but can not get inside scanner itself. Have removed screw Back L H Side, but do not wish to brake in — somthing is holding (more screws?)
    Yrs Paul D
    pauldaley08@hotmail.com
    pauldaley08 - 답글
  10. Replacing the Carriage in the Photosmart All In One Printer, Printer Carriage: 10 단계, 이미지 1/1
    • Remove printer carriage cover by unscrewing four black coarse thread T-10 torx screws marked with red circles.
  11. Replacing the Carriage in the Photosmart All In One Printer: 11 단계, 이미지 1/1
    • Depress the plastic tabs marked in red to release the cover from the sides.
  12. Replacing the Carriage in the Photosmart All In One Printer: 12 단계, 이미지 1/3 Replacing the Carriage in the Photosmart All In One Printer: 12 단계, 이미지 2/3 Replacing the Carriage in the Photosmart All In One Printer: 12 단계, 이미지 3/3
    • Slide the printer carriage to the center of the printer.
    • Disconnect the printer carriage from the rod one side at a a time by pulling upward from the bottom.
    • Unhooking the printer carriage is difficult and will require a fair amount of force.
    • The plastic strip that guides the carriage is fragile and can be broken easily.
  13. Replacing the Carriage in the Photosmart All In One Printer: 13 단계, 이미지 1/2 Replacing the Carriage in the Photosmart All In One Printer: 13 단계, 이미지 2/2
    • Pull on the two white wire strips on the printer carriage to remove which are marked in red.
    • Wire strips are fragile. Do not pull on ribbon directly. Pull from connection to carriage.
  14. Replacing the Carriage in the Photosmart All In One Printer: 14 단계, 이미지 1/3 Replacing the Carriage in the Photosmart All In One Printer: 14 단계, 이미지 2/3 Replacing the Carriage in the Photosmart All In One Printer: 14 단계, 이미지 3/3
    • Place new printer carriage on the carriage rod one side at a time.
    • For proper reassembly, place the printer carriage’s black lip beneath the overhanging metal flap located at the back of the printer.
결론
You have now successfully replaced your printer carriage for the Photosmart All In One Printer Scanner.
Follow these instructions in reverse order to reassemble your device.
다른 4명이 해당 안내서를 완성하였습니다.
Cody Long
회원 가입일: 04/12/11
153 평판
안내서 3개 작성하였습니다
Cal Poly, Team 12-31, Maness Spring 2011 Cal Poly, Team 12-31, Maness Spring 2011 회원
CPSU-MANESS-S11S12G31
5 회원들
안내서 9개 작성하였습니다
댓글 한 개
It would be a good idea to unhook the guide film whilst changing the carriage, then feeding it carefully through the IR head on the carriage PCB & re hooking it.
Rab - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 55
전체 시간: 10,921
