주요 콘텐츠로 건너뛰기
HP Pavilion 11 x360 Fan Replacement
필요한 것
  1. HP Pavilion 11 x360 Fan Replacement, Remove Screws: 1 단계, 이미지 2개 중 1개 HP Pavilion 11 x360 Fan Replacement, Remove Screws: 1 단계, 이미지 2개 중 2개
    • Use the spudger to pry off the two rubber feet near the hinge of the laptop. This will reveal two hidden 9mm screws.
    • You must remove eleven screws.
    • Four 9mm screws with the PH0 screwdriver.
    • Seven 6mm screws with the PH0 screwdriver.
  2. HP Pavilion 11 x360 Fan Replacement, Remove Backing: 2 단계, 이미지 3개 중 1개 HP Pavilion 11 x360 Fan Replacement, Remove Backing: 2 단계, 이미지 3개 중 2개 HP Pavilion 11 x360 Fan Replacement, Remove Backing: 2 단계, 이미지 3개 중 3개
    • Use the spudger to pry the corners of the laptop near the display hinges.
    • Pry around the seam of the laptop with the plastic opening tool until the backing begins to pull apart.
    • When you lift the bottom cover, there is a cable connected between the motherboard and the bottom cover. Be careful not to pull the cable loose!
  3. HP Pavilion 11 x360 Fan Replacement, Detach Cable: 3 단계, 이미지 2개 중 1개 HP Pavilion 11 x360 Fan Replacement, Detach Cable: 3 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to lift the white tab up at the connection.
    • Pull the cable outwards.
  4. HP Pavilion 11 x360 Fan Replacement, Remove Screws: 4 단계, 이미지 1개 중 1개
    • Remove the two 3mm screws with the PH0 screwdriver.
  5. HP Pavilion 11 x360 Fan Replacement, Disconnect Cable: 5 단계, 이미지 2개 중 1개 HP Pavilion 11 x360 Fan Replacement, Disconnect Cable: 5 단계, 이미지 2개 중 2개
    • Use your fingernails to slowly loosen the fan connection cable.
    • After the cable is slightly pulled from the connection, grab the cable and pull it outwards.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Natalie
회원 가입일: 01/22/15
937 평판
안내서 4개를 작성함
Cal Poly, Team 19-9, Maness Winter 2015 Cal Poly, Team 19-9, Maness Winter 2015 회원
CPSU-MANESS-W15S19G9
4 회원들
안내서 12개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 15
지난 30일: 37
전체 시간: 2,885
