소개
Make sure your device is completely powered off and unplugged from any power source before beginning.
필요한 것
Use the spudger to pry off the two rubber feet near the hinge of the laptop. This will reveal two hidden 9mm screws.
You must remove eleven screws.
Four 9mm screws with the PH0 screwdriver.
Seven 6mm screws with the PH0 screwdriver.
Use the spudger to pry the corners of the laptop near the display hinges.
Pry around the seam of the laptop with the plastic opening tool until the backing begins to pull apart.
Use the plastic opening tool to lift the white tab up at the connection.
Pull the cable outwards.
Remove the battery.
I found the battery on Amazon
Könnten Sie mir bitte sagen, was für ein Akku verwendet worden ist.
das wäre für mich sehr hilfreich.
Vielen Dank
Use your fingernails to slowly loosen the fan connection cable.
After the cable is slightly pulled from the connection, grab the cable and pull it outwards.
Remove the three 3mm screws using the PH0 screwdriver.
Pull the hard drive slightly away from the connection to easily disconnect the hard drive cable from the motherboard.
Remove the hard drive.
Unscrew the two 3mm screws with the PH0 screwdriver.
Pull the wireless card out of its port to disconnect it from the motherboard.
Push the black tab away from the hinge of the laptop.
After the black tab has been flipped, pull out the blue cable to disconnect the keyboard cable.
Pull horizontally toward the hinge of the laptop to disconnect the webcam cable.
Pull the cable horizontally away from the motherboard to disconnect the power button board cable.
Pull the cable horizontally away from the motherboard to disconnect the power connector cable.
Pull the cable horizontally away from the motherboard to disconnect the speaker cable.
Push the white tab up toward the hinge of the laptop.
Disconnect touch pad cable by pulling up and away from the motherboard.
Remove the fifteen 3mm screws connected directly to the keyboard using the PH0 screwdriver.
Remove the 3mm screw under the keyboard cable using the PH0 screwdriver.
Remove the two 3mm screws attached to the power button board.
Lift out power button board.
다른 9명이 해당 안내서를 완성하였습니다.
댓글 3개
I just replaced my keyboard and everything was exactly like the guide. Worked perfectly.
Hello, I'm the computer tech for a school, we have about 500 HP Probook x360 11 G1 EE, and often the key pop out and the hinge are broken, not the key. Where can I buy a bunch (like 25+) of hinges only.
