주요 콘텐츠로 건너뛰기
HP Pavilion 11 x360 Speakers Replacement
필요한 것
  1. HP Pavilion 11 x360 Speakers Replacement, Remove Screws: 1 단계, 이미지 1/2 HP Pavilion 11 x360 Speakers Replacement, Remove Screws: 1 단계, 이미지 2/2
    • Use the spudger to pry off the two rubber feet near the hinge of the laptop. This will reveal two hidden 9mm screws.
    • You must remove eleven screws.
    • Four 9mm screws with the PH0 screwdriver.
    • Seven 6mm screws with the PH0 screwdriver.
  2. HP Pavilion 11 x360 Speakers Replacement, Remove Backing: 2 단계, 이미지 1/3 HP Pavilion 11 x360 Speakers Replacement, Remove Backing: 2 단계, 이미지 2/3 HP Pavilion 11 x360 Speakers Replacement, Remove Backing: 2 단계, 이미지 3/3
    • Use the spudger to pry the corners of the laptop near the display hinges.
    • Pry around the seam of the laptop with the plastic opening tool until the backing begins to pull apart.
    • When you lift the bottom cover, there is a cable connected between the motherboard and the bottom cover. Be careful not to pull the cable loose!
  3. HP Pavilion 11 x360 Speakers Replacement, Detach Cable: 3 단계, 이미지 1/2 HP Pavilion 11 x360 Speakers Replacement, Detach Cable: 3 단계, 이미지 2/2
    • Use the plastic opening tool to lift the white tab up at the connection.
    • Pull the cable outwards.
  4. HP Pavilion 11 x360 Speakers Replacement, Battery: 4 단계, 이미지 1/1
    • Remove the four 6mm screws from the battery with the PH0 screwdriver.
  5. HP Pavilion 11 x360 Speakers Replacement: 5 단계, 이미지 1/3 HP Pavilion 11 x360 Speakers Replacement: 5 단계, 이미지 2/3 HP Pavilion 11 x360 Speakers Replacement: 5 단계, 이미지 3/3
    • Use the spudger to pry up the blue/white speaker wires that are routed beside the battery.
  6. HP Pavilion 11 x360 Speakers Replacement: 6 단계, 이미지 1/2 HP Pavilion 11 x360 Speakers Replacement: 6 단계, 이미지 2/2
    • Remove the battery cable from the motherboard by gently pulling out on the black part of the cable closest to the white tab.
  7. HP Pavilion 11 x360 Speakers Replacement: 7 단계, 이미지 1/2 HP Pavilion 11 x360 Speakers Replacement: 7 단계, 이미지 2/2
    • Remove the battery.
  8. HP Pavilion 11 x360 Speakers Replacement, Speakers: 8 단계, 이미지 1/3 HP Pavilion 11 x360 Speakers Replacement, Speakers: 8 단계, 이미지 2/3 HP Pavilion 11 x360 Speakers Replacement, Speakers: 8 단계, 이미지 3/3
    • Remove two 6mm screws on each speaker with the PH0 screwdriver.
  9. HP Pavilion 11 x360 Speakers Replacement: 9 단계, 이미지 1/3 HP Pavilion 11 x360 Speakers Replacement: 9 단계, 이미지 2/3 HP Pavilion 11 x360 Speakers Replacement: 9 단계, 이미지 3/3
    • Disconnect the black cable that attaches the speakers to the motherboard by gently pulling the cable outward.
    • Remove the speakers.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Natalie
회원 가입일: 01/22/15
937 평판
안내서 4개 작성하였습니다
Cal Poly, Team 19-9, Maness Winter 2015 Cal Poly, Team 19-9, Maness Winter 2015 회원
CPSU-MANESS-W15S19G9
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 1,574
