소개
If the bottom case of your device become cracked or damaged, this guide will show you how to replace it.
필요한 것
Use the nylon spudger to remove the rubber pads near the hinge for the screen. Then remove the screws under the pads.
Use Phillips #0 to remove four 9mm screws.
Use Phillips #0 to remove seven 6mm screws.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
