소개
This guide will instruct a user on how to remove the fan in order to replace a potentially faulty piece of hardware. Be sure the device is turned off and disconnected from all power sources.
필요한 것
Use the nylon spudger to remove the rubber pads near the hinge of the screen, then remove the screws under the pads.
Use the Phillips #0 to remove four 9mm screws.
Use the Phillips #0 to remove seven 6mm screws.
다른 2명이 해당 안내서를 완성하였습니다.
