주요 콘텐츠로 건너뛰기
HP Pavilion 11-n010dx Hard Drive Replacement
필요한 것
  1. HP Pavilion 11-n010dx Hard Drive Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Pavilion 11-n010dx Hard Drive Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Use the nylon spudger to remove the rubber pads near the hinge of the screen, then remove the screws under the pads.
    • Use the Phillips #0 to remove four 9mm screws.
    • Use the Phillips #0 to remove seven 6mm screws.
  2. HP Pavilion 11-n010dx Hard Drive Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion 11-n010dx Hard Drive Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion 11-n010dx Hard Drive Replacement: 2 단계, 이미지 3개 중 3개
    • Use the nylon spudger to pry the back casing near the hinges for the screen.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
    • Careful when beginning to remove the case. There is a cable attached between the bottom case and the motherboard that must be properly disconnected.
  3. HP Pavilion 11-n010dx Hard Drive Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion 11-n010dx Hard Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Use the blue plastic opening tool to lift up on the white tab that is holding the cable in place on the motherboard.
    • Now carefully pull the cable out of place and remove the entire back casing.
  4. HP Pavilion 11-n010dx Hard Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the five 6mm screws that hold the battery in place using the Phillips #0.
  5. HP Pavilion 11-n010dx Hard Drive Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion 11-n010dx Hard Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Use the nylon spudger to pry away the blue/white wire that is positioned near your battery.
  6. HP Pavilion 11-n010dx Hard Drive Replacement: 6 단계, 이미지 2개 중 1개 HP Pavilion 11-n010dx Hard Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  7. HP Pavilion 11-n010dx Hard Drive Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the battery from your device.
  8. HP Pavilion 11-n010dx Hard Drive Replacement, Hard Drive: 8 단계, 이미지 1개 중 1개
    • Use the Phillips #0 to remove the three 3mm screws holding the hard drive in place.
  9. HP Pavilion 11-n010dx Hard Drive Replacement: 9 단계, 이미지 2개 중 1개 HP Pavilion 11-n010dx Hard Drive Replacement: 9 단계, 이미지 2개 중 2개
    • Carefully lift the hard drive out of place using the tag.
  10. HP Pavilion 11-n010dx Hard Drive Replacement: 10 단계, 이미지 3개 중 1개 HP Pavilion 11-n010dx Hard Drive Replacement: 10 단계, 이미지 3개 중 2개 HP Pavilion 11-n010dx Hard Drive Replacement: 10 단계, 이미지 3개 중 3개
    • Gently pull on the cable connector to disconnect the hard drive from your device.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Joseph Lintz
회원 가입일: 09/15/16
939 평판
안내서 5개를 작성함
USF Tampa, Team 11-5, Blackwell Fall 2016 USF Tampa, Team 11-5, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S11G5
3 회원들
안내서 10개를 작성함
댓글 2개
Thanks a lot Joseph ! Works well for the model 11-n000nf !
Nicolas - 답글
Thanks Joseph-I was able to get it open, disconnect the battery and ordered a new battery. We’ll see if this corrects the problem. Computer was sleeping for over a year. Thank you for your pictures and easy to follow instructions.
Beverlyn - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 33
전체 시간: 5,729
