소개
The hard drive of your device is where all of the information is kept. Issues with your hard drive can cause a slower moving device, PC errors and lack of free space on your device. Replacing this item will solve these problems. Be sure the device is turned off and disconnected from all power sources.
필요한 것
Use the nylon spudger to remove the rubber pads near the hinge of the screen, then remove the screws under the pads.
Use the Phillips #0 to remove four 9mm screws.
Use the Phillips #0 to remove seven 6mm screws.
Use the Phillips #0 to remove the three 3mm screws holding the hard drive in place.
다른 5명이 해당 안내서를 완성하였습니다.
