주요 콘텐츠로 건너뛰기
HP Pavilion 11-n010dx Ram Replacement
필요한 것
  1. HP Pavilion 11-n010dx Ram Replacement, Battery: 1 단계, 이미지 1/2 HP Pavilion 11-n010dx Ram Replacement, Battery: 1 단계, 이미지 2/2
    • Use the nylon spudger to remove the rubber pads near the hinge of the screen, then remove the screws under the pads.
    • Use the Phillips #0 to remove four 9mm screws.
    • Use the Phillips #0 to remove seven 6mm screws.
  2. HP Pavilion 11-n010dx Ram Replacement: 2 단계, 이미지 1/3 HP Pavilion 11-n010dx Ram Replacement: 2 단계, 이미지 2/3 HP Pavilion 11-n010dx Ram Replacement: 2 단계, 이미지 3/3
    • Use the nylon spudger to pry the back casing near the hinges for the screen.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
    • Careful when beginning to remove the case. There is a cable attached between the bottom case and the motherboard that must be properly disconnected.
  3. HP Pavilion 11-n010dx Ram Replacement: 3 단계, 이미지 1/2 HP Pavilion 11-n010dx Ram Replacement: 3 단계, 이미지 2/2
    • Use the blue plastic opening tool to lift up on the white tab that is holding the cable in place on the motherboard.
    • Now carefully pull the cable out of place and remove the entire back casing.
  4. HP Pavilion 11-n010dx Ram Replacement: 4 단계, 이미지 1/1
    • Remove the five 6mm screws that hold the battery in place using the Phillips #0.
  5. HP Pavilion 11-n010dx Ram Replacement: 5 단계, 이미지 1/2 HP Pavilion 11-n010dx Ram Replacement: 5 단계, 이미지 2/2
    • Use the nylon spudger to pry away the blue/white wire that is positioned near your battery.
  6. HP Pavilion 11-n010dx Ram Replacement: 6 단계, 이미지 1/2 HP Pavilion 11-n010dx Ram Replacement: 6 단계, 이미지 2/2
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  7. HP Pavilion 11-n010dx Ram Replacement: 7 단계, 이미지 1/1
    • Remove the battery from your device.
  8. HP Pavilion 11-n010dx Ram Replacement, Ram: 8 단계, 이미지 1/2 HP Pavilion 11-n010dx Ram Replacement, Ram: 8 단계, 이미지 2/2
    • Using your fingernails, pull the tabs on either side of the RAM to release the module from its secured spot.
  9. HP Pavilion 11-n010dx Ram Replacement: 9 단계, 이미지 1/2 HP Pavilion 11-n010dx Ram Replacement: 9 단계, 이미지 2/2
    • Carefully grab and pull to remove the RAM from your device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Joseph Lintz
회원 가입일: 09/15/16
915 평판
안내서 5개 작성하였습니다
USF Tampa, Team 11-5, Blackwell Fall 2016 USF Tampa, Team 11-5, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S11G5
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 756
