주요 콘텐츠로 건너뛰기
HP Pavilion 13-s128nr Back Panel Replacement
필요한 것
  1. HP Pavilion 13-s128nr Back Panel Replacement, Back Panel: 1 단계, 이미지 1/2 HP Pavilion 13-s128nr Back Panel Replacement, Back Panel: 1 단계, 이미지 2/2
    • Use the iFixit opening tool to take off the rubber caps.
    • Remove the screws using the Phillips #0 screwdriver.
  2. HP Pavilion 13-s128nr Back Panel Replacement: 2 단계, 이미지 1/1
    • Use the Jimmy to pry around the seam of the laptop.
    • Remove the back panel of the laptop.
    • Don't completely remove the back panel as there are ribbon cables that can be easily damaged if removed quickly.
  3. HP Pavilion 13-s128nr Back Panel Replacement: 3 단계, 이미지 1/2 HP Pavilion 13-s128nr Back Panel Replacement: 3 단계, 이미지 2/2
    • Using the iFixit opening tool to lift the tabs holding in the cables connecting the keyboard to the motherboard.
    • Pull the cable from the motherboard.
결론
Sydney Bell
회원 가입일: 02/13/20
317 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 13
전체 시간: 789
