주요 콘텐츠로 건너뛰기
HP Pavilion 14-b015dx Keyboard Replacement
필요한 것
  1. HP Pavilion 14-b015dx Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure the computer is completely powered down and unplug the power cord.
  2. HP Pavilion 14-b015dx Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Place the device on your work surface with bottom facing up and the battery located at the top.
  3. HP Pavilion 14-b015dx Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the left release tab toward the center of the computer to the unlock position. Next slid the right tab toward the center of the computer and hold it there while completing step 4.
  4. HP Pavilion 14-b015dx Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the battery by sliding it upwards and away from the computer.
  5. HP Pavilion 14-b015dx Keyboard Replacement, Keyboard: 5 단계, 이미지 1개 중 1개
    • Unscrew the ten 6.0 mm Philips head screws on the base of the device with a Phillips #0 head screwdriver.
  6. HP Pavilion 14-b015dx Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    • Insert the plastic opening tool between the keyboard and the plastic housing.
    • Pry the keyboard upward away from the device.
    • Move the tool around the edge of the entire keyboard while continuing to pry.
    • You will hear the clips pop once you have released them.
  7. HP Pavilion 14-b015dx Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    • Once you have released all of the clips, slowly lift the keyboard exposing the ribbon cable.
    • Lift the tab on the keyboard ZIF connector with a plastic opening tool and gently remove the ribbon cable.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Gregory Bridge
회원 가입일: 10/24/17
638 평판
안내서 6개를 작성함
UMass Dartmouth, Team S1-G1, Isaacson Fall 2017 UMass Dartmouth, Team S1-G1, Isaacson Fall 2017 회원
UMASSD-ISAACSON-F17S1G1
3 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 11
전체 시간: 1,554
