주요 콘텐츠로 건너뛰기
HP Pavilion 14-b015dx Palm Rest Replacement
필요한 것
  1. HP Pavilion 14-b015dx Palm Rest Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the computer is completely powered down and unplug the power cord.
  2. HP Pavilion 14-b015dx Palm Rest Replacement: 2 단계, 이미지 1/1
    • Place the device on your work surface with bottom facing up and the battery located at the top.
  3. HP Pavilion 14-b015dx Palm Rest Replacement: 3 단계, 이미지 1/1
    • Slide the left release tab toward the center of the computer to the unlock position. Next slid the right tab toward the center of the computer and hold it there while completing step 4.
  4. HP Pavilion 14-b015dx Palm Rest Replacement: 4 단계, 이미지 1/1
    • Remove the battery by sliding it upwards and away from the computer.
  5. HP Pavilion 14-b015dx Palm Rest Replacement, Keyboard: 5 단계, 이미지 1/1
    • Unscrew the ten 6.0 mm Philips head screws on the base of the device with a Phillips #0 head screwdriver.
  6. HP Pavilion 14-b015dx Palm Rest Replacement: 6 단계, 이미지 1/1
    • Insert the plastic opening tool between the keyboard and the plastic housing.
    • Pry the keyboard upward away from the device.
    • Move the tool around the edge of the entire keyboard while continuing to pry.
    • You will hear the clips pop once you have released them.
  7. HP Pavilion 14-b015dx Palm Rest Replacement: 7 단계, 이미지 1/1
    • Once you have released all of the clips, slowly lift the keyboard exposing the ribbon cable.
    • Lift the tab on the keyboard ZIF connector with a plastic opening tool and gently remove the ribbon cable.
  8. HP Pavilion 14-b015dx Palm Rest Replacement, Palm Rest: 8 단계, 이미지 1/1
    • Remove the eight 6.0 mm screws located under the keyboard with your Philips #0 screwdriver.
  9. HP Pavilion 14-b015dx Palm Rest Replacement: 9 단계, 이미지 1/1
    • Remove the track pad and power button ribbon cables.
    • Lift the locking bar on each connector with a plastic opening tool and gently remove the ribbon cables
  10. HP Pavilion 14-b015dx Palm Rest Replacement: 10 단계, 이미지 1/1
    • To remove the palm rest, insert the plastic opening tool in the seam between the palm rest and the base.
    • Pry upward to undo each clip.
    • Continue this process around the entire palm rest.
  11. HP Pavilion 14-b015dx Palm Rest Replacement: 11 단계, 이미지 1/1
    • Once all clips have been undone lift the palm rest away from the laptop.
결론
Gregory Bridge
회원 가입일: 10/24/17
623 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S1-G1, Isaacson Fall 2017 UMass Dartmouth, Team S1-G1, Isaacson Fall 2017 회원
UMASSD-ISAACSON-F17S1G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 5
30일 전: 11
전체 시간: 361
