주요 콘텐츠로 건너뛰기
HP Pavilion 14-b120dx Keyboard Replacement
필요한 것
  1. HP Pavilion 14-b120dx Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Power down the laptop and detach the charging cord (failure to do so can result in electrical shock).
  2. HP Pavilion 14-b120dx Keyboard Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion 14-b120dx Keyboard Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion 14-b120dx Keyboard Replacement: 2 단계, 이미지 3개 중 3개
    • Flip the laptop upside down so that the bottom is facing you.
    • Push the slide on the right toward the center of the laptop, releasing the battery latch.
    • Lift the battery up and away from the laptop.
  3. HP Pavilion 14-b120dx Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 1개 HP Pavilion 14-b120dx Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 2개 HP Pavilion 14-b120dx Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool between the keyboard and the palm rest.
    • Pry upwards until the keyboard section detaches from the laptop.
    • Repeat this around the edge of the entire keyboard.
    • Sections will make loud snapping noises as they detach from the palm rest - this is normal.
  4. HP Pavilion 14-b120dx Keyboard Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion 14-b120dx Keyboard Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the keyboard slowly up until the connecting cable is exposed.
    • Carefully lift the flap on the ZIF connector using a fingernail or plastic opening tool. This will release the cable.
    • Detach the cable.
결론
작성자
6다른 기여자 명과 함께
Joshua Carberry
회원 가입일: 10/20/16
240 평판
안내서 2개를 작성함
UMass Dartmouth, Team 4-4, Catania Fall 2016 UMass Dartmouth, Team 4-4, Catania Fall 2016 회원
UMASSD-CATANIA-F16S4G4
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 1,114
