주요 콘텐츠로 건너뛰기
HP Pavilion 14-b120dx Wireless Card Replacement
필요한 것
  1. HP Pavilion 14-b120dx Wireless Card Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Power down the laptop and detach the charging cord (failure to do so can result in electrical shock).
  2. HP Pavilion 14-b120dx Wireless Card Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion 14-b120dx Wireless Card Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion 14-b120dx Wireless Card Replacement: 2 단계, 이미지 3개 중 3개
    • Flip the laptop upside down so that the bottom is facing you.
    • Push the slide on the right toward the center of the laptop, releasing the battery latch.
    • Lift the battery up and away from the laptop.
  3. HP Pavilion 14-b120dx Wireless Card Replacement, Keyboard: 3 단계, 이미지 3개 중 1개 HP Pavilion 14-b120dx Wireless Card Replacement, Keyboard: 3 단계, 이미지 3개 중 2개 HP Pavilion 14-b120dx Wireless Card Replacement, Keyboard: 3 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool between the keyboard and the palm rest.
    • Pry upwards until the keyboard section detaches from the laptop.
    • Repeat this around the edge of the entire keyboard.
    • Sections will make loud snapping noises as they detach from the palm rest - this is normal.
  4. HP Pavilion 14-b120dx Wireless Card Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion 14-b120dx Wireless Card Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the keyboard slowly up until the connecting cable is exposed.
    • Carefully lift the flap on the ZIF connector using a fingernail or plastic opening tool. This will release the cable.
    • Detach the cable.
  5. HP Pavilion 14-b120dx Wireless Card Replacement, Palm Rest: 5 단계, 이미지 2개 중 1개 HP Pavilion 14-b120dx Wireless Card Replacement, Palm Rest: 5 단계, 이미지 2개 중 2개
    • Unscrew the 10 6.0 mm screws under the keyboard housing with a Philips #0 head screwdriver.
  6. HP Pavilion 14-b120dx Wireless Card Replacement: 6 단계, 이미지 3개 중 1개 HP Pavilion 14-b120dx Wireless Card Replacement: 6 단계, 이미지 3개 중 2개 HP Pavilion 14-b120dx Wireless Card Replacement: 6 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool into the seam between the palm rest and the laptop.
    • Pry upwards until the palm rest separates from the laptop.
    • Repeat this process around the entire computer.
    • These steps will be similar to the ones you took to remove the keyboard. Again, you will hear snapping noises.
  7. HP Pavilion 14-b120dx Wireless Card Replacement: 7 단계, 이미지 1개 중 1개
    • Lift upwards to remove the palm rest.
  8. HP Pavilion 14-b120dx Wireless Card Replacement, Wireless Card: 8 단계, 이미지 2개 중 1개 HP Pavilion 14-b120dx Wireless Card Replacement, Wireless Card: 8 단계, 이미지 2개 중 2개
    • Remove the two 4.0 mm screws using a Philips #00 head screwdriver.
  9. HP Pavilion 14-b120dx Wireless Card Replacement: 9 단계, 이미지 2개 중 1개 HP Pavilion 14-b120dx Wireless Card Replacement: 9 단계, 이미지 2개 중 2개
    • Detach the two wires connecting to the motherboard to the wireless card.
  10. HP Pavilion 14-b120dx Wireless Card Replacement: 10 단계, 이미지 2개 중 1개 HP Pavilion 14-b120dx Wireless Card Replacement: 10 단계, 이미지 2개 중 2개
    • Slide the card upwards and outwards to detach it from the motherboard.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Erin Lavalla
회원 가입일: 10/18/16
458 평판
안내서 4개를 작성함
UMass Dartmouth, Team 4-4, Catania Fall 2016 UMass Dartmouth, Team 4-4, Catania Fall 2016 회원
UMASSD-CATANIA-F16S4G4
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 12
전체 시간: 703
