주요 콘텐츠로 건너뛰기
HP Pavilion 14-bk061st Motherboard Replacement
필요한 것
  1. HP Pavilion 14-bk061st Motherboard Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 HP Pavilion 14-bk061st Motherboard Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
    • Remove the three 5.7 JIS #1 screws from the bottom of the laptop.
    • Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
  2. HP Pavilion 14-bk061st Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Unclip the back plate using a plastic opening tool.
  3. HP Pavilion 14-bk061st Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully remove the back plate from the laptop.
  4. HP Pavilion 14-bk061st Motherboard Replacement, RAM Card: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Halberd Spudger
    $2.99
    • Use the hook end of the Halberd spudger to pull back the clamps holding the card in place.
    • Take care when pulling the second clamp as the card has a tendency to jump out.
  5. HP Pavilion 14-bk061st Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the card by pulling it up and away from the slot.
  6. HP Pavilion 14-bk061st Motherboard Replacement, WLAN Card: 6 단계, 이미지 2개 중 1개 HP Pavilion 14-bk061st Motherboard Replacement, WLAN Card: 6 단계, 이미지 2개 중 2개
    • Disconnect the two Wi-Fi and Bluetooth antenna wires by gently pulling them away from the board.
  7. HP Pavilion 14-bk061st Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the JIS #1 screw from the WLAN card.
  8. HP Pavilion 14-bk061st Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the card by pulling it away from the slot.
  9. HP Pavilion 14-bk061st Motherboard Replacement, Heat Sink: 9 단계, 이미지 2개 중 1개 HP Pavilion 14-bk061st Motherboard Replacement, Heat Sink: 9 단계, 이미지 2개 중 2개
    • Remove the four 2.9mm JIS #1 screws from each of the four corners of the fan.
  10. HP Pavilion 14-bk061st Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Carefully grab the heat sink from any side and lift straight up while trying to avoid touching other components.
    • Avoid bending the heat-pipe at all costs to keep it functional.
  11. HP Pavilion 14-bk061st Motherboard Replacement, Fan: 11 단계, 이미지 1개 중 1개
    • Remove the three 2.9mm JIS #1 screws surrounding the fan.
  12. HP Pavilion 14-bk061st Motherboard Replacement: 12 단계, 이미지 2개 중 1개 HP Pavilion 14-bk061st Motherboard Replacement: 12 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Carefully lift up the fan without tugging out the attached wire, and lay it on the motherboard.
    • Use tweezers to gently unplug the power connector wire.
    • Remove the fan from the laptop.
  13. HP Pavilion 14-bk061st Motherboard Replacement, Motherboard: 13 단계, 이미지 1개 중 1개
    • Remove the seven screws from the motherboard using a JIS #1 screwdriver.
  14. HP Pavilion 14-bk061st Motherboard Replacement: 14 단계, 이미지 2개 중 1개 HP Pavilion 14-bk061st Motherboard Replacement: 14 단계, 이미지 2개 중 2개
    • Remove the nine cables from the motherboard by carefully lifting the black tab on each connector.
  15. HP Pavilion 14-bk061st Motherboard Replacement: 15 단계, 이미지 1개 중 1개
    • Carefully remove the motherboard from the casing.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Mehrab Daemi
회원 가입일: 01/22/20
596 평판
안내서 4개를 작성함
York University, Team S8-G3, Turner Winter 2020 York University, Team S8-G3, Turner Winter 2020 회원
YORK-TURNER-W20S8G3
4 회원들
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 20
전체 시간: 1,187
