주요 콘텐츠로 건너뛰기
HP Pavilion 14-bk061st Screen Replacement
필요한 것
  1. HP Pavilion 14-bk061st Screen Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 HP Pavilion 14-bk061st Screen Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
    • Remove the three 5.7 JIS #1 screws from the bottom of the laptop.
    • Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
  2. HP Pavilion 14-bk061st Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Unclip the back plate using a plastic opening tool.
  3. HP Pavilion 14-bk061st Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully remove the back plate from the laptop.
  4. HP Pavilion 14-bk061st Screen Replacement, Screen: 4 단계, 이미지 2개 중 1개 HP Pavilion 14-bk061st Screen Replacement, Screen: 4 단계, 이미지 2개 중 2개
    • Remove the five JIS #1 screws that attach the hinges of the screen to the casing of the laptop.
  5. HP Pavilion 14-bk061st Screen Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion 14-bk061st Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Carefully lift the hinges from the encasing and lift the bottom half of the laptop away from the screen.
  6. HP Pavilion 14-bk061st Screen Replacement: 6 단계, 이미지 3개 중 1개 HP Pavilion 14-bk061st Screen Replacement: 6 단계, 이미지 3개 중 2개 HP Pavilion 14-bk061st Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Use the metal spudger to carefully pry off the plastic encasing around the monitor.
    • Use the outside of the screen to remove the plastic encasing to avoid damaging the screen itself.
  7. HP Pavilion 14-bk061st Screen Replacement: 7 단계, 이미지 2개 중 1개 HP Pavilion 14-bk061st Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the four JIS #1 screws holding the screen in place.
  8. HP Pavilion 14-bk061st Screen Replacement: 8 단계, 이미지 3개 중 1개 HP Pavilion 14-bk061st Screen Replacement: 8 단계, 이미지 3개 중 2개 HP Pavilion 14-bk061st Screen Replacement: 8 단계, 이미지 3개 중 3개
    • Carefully remove the sticker covering the wire that connects the screen to the motherboard.
    • Disconnect the cable that is connected to the screen.
  9. HP Pavilion 14-bk061st Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the screen from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Mehrab Daemi
회원 가입일: 01/22/20
596 평판
안내서 4개를 작성함
York University, Team S8-G3, Turner Winter 2020 York University, Team S8-G3, Turner Winter 2020 회원
YORK-TURNER-W20S8G3
4 회원들
안내서 11개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 10
전체 시간: 932
