주요 콘텐츠로 건너뛰기
HP Pavilion 14-c015dx Chromebook Keyboard Replacement
필요한 것
  1. HP Pavilion 14-c015dx Chromebook Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Remove the two 7mm screws with a Phillips Head #1 Screwdriver.
    • These screws may not completely come out of the laptop, so just make sure that you have loosened them all of the way.
  2. HP Pavilion 14-c015dx Chromebook Keyboard Replacement: 2 단계, 이미지 1/2 HP Pavilion 14-c015dx Chromebook Keyboard Replacement: 2 단계, 이미지 2/2
    • Starting from the left side, use the metal spudger to pry off the keyboard.
    • Run the spudger across the edges until all plastic clips are popped up and the keyboard is free from the palm rest assembly.
    • Do not pull the keyboard away from the computer while popping the keyboard off, there is a connector cable in the bottom center of the keyboard that will be disconnected in the next step.
  3. HP Pavilion 14-c015dx Chromebook Keyboard Replacement: 3 단계, 이미지 1/3 HP Pavilion 14-c015dx Chromebook Keyboard Replacement: 3 단계, 이미지 2/3 HP Pavilion 14-c015dx Chromebook Keyboard Replacement: 3 단계, 이미지 3/3
    • Detach the circuit connector by flipping up the black flap upwards and gently pulling the connector out by pulling up on the blue release tab.
    • Lift the keyboard away from the computer once the connector is detached.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Joe Kennedy
회원 가입일: 01/23/17
231 평판
안내서 2개 작성하였습니다
Cal Poly, Team 22-8, Maness Winter 2017 Cal Poly, Team 22-8, Maness Winter 2017 회원
CPSU-MANESS-W17S22G8
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 7
전체 시간: 451
