주요 콘텐츠로 건너뛰기
HP Pavilion 14-cf0014dx Daughterboard Replacement
필요한 것
  1. HP Pavilion 14-cf0014dx Daughterboard Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Flip the device over so that the backside is facing you.
    • Remove the rubber feet to expose six screws.
    • Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
  2. HP Pavilion 14-cf0014dx Daughterboard Replacement: 2 단계, 이미지 1개 중 1개
    • Insert a plastic opening tool and run it along the edges of the laptop.
    • Remove the back panel from the device.
  3. HP Pavilion 14-cf0014dx Daughterboard Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
  4. HP Pavilion 14-cf0014dx Daughterboard Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the battery up and out and remove it from the device.
  5. HP Pavilion 14-cf0014dx Daughterboard Replacement, Daughterboard: 5 단계, 이미지 1개 중 1개
    • Remove the two 6.7 mm screws with a Phillips #0 screwdriver.
  6. HP Pavilion 14-cf0014dx Daughterboard Replacement: 6 단계, 이미지 2개 중 1개 HP Pavilion 14-cf0014dx Daughterboard Replacement: 6 단계, 이미지 2개 중 2개
    • Unlock the ZIF connector with the tip of the spudger.
    • Remove the ribbon cable.
  7. HP Pavilion 14-cf0014dx Daughterboard Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the daughterboard with a pair of tweezers.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
작성자
2다른 기여자 명과 함께
Angel S
회원 가입일: 02/08/24
205 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 17
전체 시간: 264
