주요 콘텐츠로 건너뛰기
HP Pavilion 14-cf0014dx Display Assembly Replacement
필요한 것
  1. HP Pavilion 14-cf0014dx Display Assembly Replacement, Back Panel: 1 단계, 이미지 1/1
    • Flip the device over so that the backside is facing you.
    • Remove the rubber feet to expose six screws.
    • Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
  2. HP Pavilion 14-cf0014dx Display Assembly Replacement: 2 단계, 이미지 1/1
    • Insert a plastic opening tool and run it along the edges of the laptop.
    • Remove the back panel from the device.
  3. HP Pavilion 14-cf0014dx Display Assembly Replacement, Battery: 3 단계, 이미지 1/1
    • Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
  4. HP Pavilion 14-cf0014dx Display Assembly Replacement: 4 단계, 이미지 1/1
    • Lift the battery up and out and remove it from the device.
  5. HP Pavilion 14-cf0014dx Display Assembly Replacement, Display Assembly: 5 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the 6.8 mm screws securing the hinges.
  6. HP Pavilion 14-cf0014dx Display Assembly Replacement: 6 단계, 이미지 1/2 HP Pavilion 14-cf0014dx Display Assembly Replacement: 6 단계, 이미지 2/2
    • Use tweezers to detach the coaxial cables from the Wi-Fi card.
    • Hold the tweezers closer to the metal pin to avoid ripping the cable and damaging the connector when removing the clip.
  7. HP Pavilion 14-cf0014dx Display Assembly Replacement: 7 단계, 이미지 1/2 HP Pavilion 14-cf0014dx Display Assembly Replacement: 7 단계, 이미지 2/2
    • First, gently push the tip of a spudger under the metal buckle of the display cable connector to unclip it, then swing it over the socket.
    • Next, hold the buckle and cable together and gently pull the connector straight out of its socket.
    • To reconnect:
    • Grip the cable and buckle together and insert the connector fully into its socket.
    • Aligning the connector can be tricky. Reposition it as necessary and don't try to force it into the socket, or you may damage both the connector and its socket.
    • Flip the buckle over the socket and use a spudger to press the buckle down until it clicks into place.
  8. HP Pavilion 14-cf0014dx Display Assembly Replacement: 8 단계, 이미지 1/1
    • Remove the display assembly from the laptop chassis with your hands.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Angel S
회원 가입일: 02/08/24
205 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 12
전체 시간: 101
