주요 콘텐츠로 건너뛰기
HP Pavilion 14-cf0014dx Fan Replacement
필요한 것
  1. HP Pavilion 14-cf0014dx Fan Replacement, Back Panel: 1 단계, 이미지 1/1
    • Flip the device over so that the backside is facing you.
    • Remove the rubber feet to expose six screws.
    • Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
  2. HP Pavilion 14-cf0014dx Fan Replacement: 2 단계, 이미지 1/1
    • Insert a plastic opening tool and run it along the edges of the laptop.
    • Remove the back panel from the device.
  3. HP Pavilion 14-cf0014dx Fan Replacement, Battery: 3 단계, 이미지 1/1
    • Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
  4. HP Pavilion 14-cf0014dx Fan Replacement: 4 단계, 이미지 1/1
    • Lift the battery up and out and remove it from the device.
  5. HP Pavilion 14-cf0014dx Fan Replacement, Fan: 5 단계, 이미지 1/1
    • Using the Phillips #0 screwdriver, remove the two screws securing the fan to the motherboard.
  6. HP Pavilion 14-cf0014dx Fan Replacement: 6 단계, 이미지 1/2 HP Pavilion 14-cf0014dx Fan Replacement: 6 단계, 이미지 2/2
    • Carefully lift the fan up and out of the device.
  7. HP Pavilion 14-cf0014dx Fan Replacement: 7 단계, 이미지 1/1
    • Disconnect the fan from the motherboard and fully remove the fan from the device.
결론
Sam Cole
회원 가입일: 10/25/21
813 평판
안내서 7개 작성하였습니다
UMass Dartmouth, Team 2-7, Sinclaire Fall 2021 UMass Dartmouth, Team 2-7, Sinclaire Fall 2021 회원
UMASSD-SINCLAIRE-F21S2G7
3 회원들
안내서 7개 작성하였습니다
댓글 한 개
Why remove the battery?
Chrillusionist - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 402
